20 Most Recent Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Questions & Answers
Install ReclaiMe file recovery from www.reclaime.com in your computer connect the hard drive and you will see the disc the way it was before. With a few clicks you will recover your files.
Western Digital... | Answered on Jun 08, 2018
If it is a matter of just the power supply failing, you can get a replacement. It is possible to remove the HD and place it in a new case with a new power supply, as well. However, if you suddenly smell something burning after that, you are on the trail to adventure. That might be a burnt out diode, easy enough for a PC repair shop to replace. Or, it might be something more serious and you would need an expensive data recover shop to get back your loss. You could call Western Digital customer service and see what they have to offer in terms of a power supply or make use of the following link:
Amazon com 12V AC power adapter for western digital elements WD6400EB035...
Western Digital... | Answered on Oct 21, 2017
In all versions of windows there are settings to view files in a folder (WDdrive).
The following images will guide you through the process.
In words you click view on the tool bar on the top of the open window. In the choices from the drop down window choose large icons.
Hope this helps?"
Western Digital... | Answered on May 06, 2017
Hello, if you have the hard drive plugged in please unplug it and boot the computer.
I’m happy to help further over the phone at https://www.6ya.com/expert/adrienne_b03fb46fc6334991
Western Digital... | Answered on Apr 22, 2017
You can print this if you need a paper manual.
Western Digital... | Answered on Jun 19, 2016
If the drive does not appear in Remove Device but does appear under computer you can right click on it then select EJECT.
Don't be panic. you can try some data recovery software. You can see
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html?part=dl-75328850&subj=dl&tag=button
It tells the steps how to perform data recovery.
If above does not work, you may have to format the external hard drive (use quick format), and then use above mentioned software to scan again the external hard drive and recover your files.
Western Digital... | Answered on Aug 27, 2015
Try going to Disk Management and see if they show up there.
  1. Click Start
  2. Right Click My Computer
  3. Click Manage
  4. Click Disk Management
If your computer is recognizing a mass storage device they should show up in disk management and you can just assign them a drive letter.
Western Digital... | Answered on Dec 05, 2014
Uninstall the driver and then reinstall. make sure the drive is not connected until the driver is installed.
Not recommended to open the case of an external hard drive. If you damage some small connector you might loose the right to replace it.
Western Digital... | Answered on Aug 17, 2014
I think this is what you need. Follow link.
Western Digital... | Answered on Jul 31, 2014
If it's the power adapter then a simple search of the internet should show you where to go to find one. The other problem is that the HDD may be bad. You'd have to open the case, remove the HDD then connect it to your computer. I'm sure this would void the warrenty. However if it is the HDD then you saved yourselp the cost of a power supply.
Western Digital... | Answered on Jun 05, 2014
What OS are you using? On Win 8/8.1/8.1 update My WD my book will blink several times and take as long as 30 seconds to display all the files.
The pcb controller needs the info transferred from the original pcb otherwise the drive will remain inaccessible or destroy the data on the drive. Take it to a professional.
http://forum.hddguru.com/viewtopic.php?t=10822&start=
Western Digital... | Answered on Apr 02, 2014
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
326 questions posted
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
ChinthakaJ
ChinthakaJ
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Elements Western Digital
  • Elements Western Digital
Most Popular Question
000 wd5000c035
  • Computers & Internet
