A power surge caused by Bose Radio to stop working.
YES IT CAN UNPLUG THE RADIO ..OPEN IT UP LOOK @ WERE THE POWER CORD COMES INTO THE RADIO SEE HOW BAD IT IS >>>IF IT IS ALL BURNT UP YOU HAVE TO GET AN IDEAR HOW MUCH A REPAIR PLACE WILL WANT>>>>>>>>BUT IT MAY ONLY BE A FUSE IN SIDE YOU MAY GET LUCKY>>>>>>>>>YOU CAN EVEN FIX THAT YOUR SELF WITH A SOLDERING IRON FROM RADIO SHACK OPEN IT UP SEE WHATS GOING ON IN SIDE MAKE SURE POWER IS UP PLUGGED GOOD LUCK
I have the same problem. Opened up my Model AWR1-1W mfd 1998. Fuse is good; continuity to it thru cord is good. Nothing is burnt on top of board. After putting together, still no power except for once, after plugging in cord at radio while other end already plugged into the wall outlet, when ALL segments of Display lit up; then nothing again after that. With all segments lit, one might think there is a logic problem as well.
