You can take the memory card out from digital recorder, and then connect the SD card to computer with a card reader, you can then follow this guide to recover your files
SD card data recovery guide
SOURCE: recover deleted files from olympus recorder srs
Yes, it's possible to recover files removed from myrecorder device. The
best way is to use a file recovery software, recommended asoftech data
recovery as it helped me before. use link below to download the software
Data Recovery Software for voice recorder
Here's a step by step guide that I find very useful
How to get back files from USB drive
Here's a video tutorial that you may take a look
SOURCE: Restoring Deleted Olympus Files
Yes, will restore any kind of files, including DSS files
Best Regards
SOURCE: deleted files and want to undelete
there is no solution... wrong type of memory for data recovery to use
SOURCE: I deleted date from Olympus VN-4100PC
When the Digital Wave Player application copies the files to yourcomputer, the default location is under My Documents>Digital WavePlayer>Message. There, you will see FolderA, FolderB, etc. +Recording & Schedule folders.
If the files are not there, use a file recovery application, such as PhotoRec to recover the deleted files.
SOURCE: Recover messages off Olympus VN-4100 Digital Voice recorder
Maybe you can rely on a Do It Yourself data recovery software to help if the storage device of your recorder is good. This recovery tool is able to recover audio, video and photo files. Good luck.
