20 Most Recent Olympus DS-40 Digital Voice Recorder Questions & Answers
2answers
Edit Comment shows error - so I cannot edit
This is actually the kind of information I have been trying to find. Thank you for writing this information. Continued
7/8/2017 7:17:39 AM • Olympus DS-40... • Answered on Jul 08, 2017
How to restore audio files from formated Olympus digital recorder
You should stop recording new ones to prevent the old ones from being overwritten. If your digital recorder has a memory card, take it out and insert it to your computer with a card reader. If the device has built-in memory, just connect it to your PC directly. On your computer, you need a video/audio recovery program. Fine one, install and run it. The software will help you scan lost audio files from your recorder, then it'll show you what it's found. Choose the files you want and hit the "Recover" button to start recovery process. If you're a Mac user, please feel free to try this Mac based video/audio recovery app. http://www.leawo.org/photo-recovery-mac/
5/17/2016 2:12:45 AM • Olympus DS-40... • Answered on May 17, 2016
Help! My Voice recorder is stuck in Slow playback/record
To switch back to normal press the PLAY button during
playback.
"Every time the PLAY button is pressed, the playback speed will switch."
5/13/2014 11:53:39 PM • Olympus DS-40... • Answered on May 13, 2014
0answers
2answers
File Recovery from Olympus VN-6200 PC voice recorder
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to another PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Good Luck!
4/5/2014 4:23:43 PM • Olympus DS-40... • Answered on Apr 05, 2014
6answers
Lost my DS-40 audio files after upload. Can I recover them?
you can use card recovery software that helped me before1. Do not save any new file to memory card.2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)http://www.asoftech.com/adr/4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your deleted files.
7/30/2013 6:26:22 AM • Olympus DS-40... • Answered on Jul 30, 2013
0answers
System check says can't be inputted into memory
On the device goto menu (by holding "ok") then sub menu then format.a on device format should fix it.
11/30/2011 9:59:02 PM • Olympus DS-40... • Answered on Nov 30, 2011
Message on attempt to record: 'input blocked'
I got this same message on my VN7000PC that I got in LIDL. The message appeared when I tried to record. I could not get it to go away. At the time I just happened to have 5 files in Folder A with lock on. I tried to remove the file locks. I got the same message "Input Blocked". That was a clue. Maybe it had something to do with the internal 1GB drive. I formatted the drive. The message disappeared and now I can record again.
HTH
Brian.
9/14/2011 9:11:01 AM • Olympus DS-40... • Answered on Sep 14, 2011
Where is the serial number
probably behind the battery.
5/11/2011 5:34:45 PM • Olympus DS-40... • Answered on May 11, 2011
4100 olympus digi voice recorder
unfortunately if you have the 4100 and not the 4100-pc you cant upload the files..
3/31/2011 6:35:05 AM • Olympus DS-40... • Answered on Mar 31, 2011
Ds-40 can deleted files be restored?
In this case you should connect your recorder to PC and then you can try to restore your files with Easy Drive Data Recovery software:
http://www.munsoft.com/EasyDriveDataRecovery/
It uses unique modern algorithms to recover files that other software either recovers incorrectly or is unable to detect.
2/25/2011 12:07:53 PM • Olympus DS-40... • Answered on Feb 25, 2011
Ds-40 deleted files then recorded
NO.
2/25/2011 1:58:51 AM • Olympus DS-40... • Answered on Feb 25, 2011
My olympus ds4000 gave a
Operators manuals are available at www.olympusamerica.com
11/9/2010 3:35:33 PM • Olympus DS-40... • Answered on Nov 09, 2010
Olympus DS-40 Digital Voice Recorder Logo
40 questions posted
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Audio Players & Recorders
Most Popular Question
lost ds 40 audio files after upload
  • Audio Players & Recorders
