20 Most Recent Olympus VN6200 Digital Voice Recorder Questions & Answers
could be corrupted memory. leave battery out of recorder for a couple days to allow the recorder to reset... get new batteries.
Olympus VN6200... | Answered on May 24, 2019
I'm not aware of the model number given, but there could be a number of issues, such a a damaged hard drive, a virus, or a bad boot record. If it is the latter, then try the following:
Insert your Windows XP CD and if you receive a message to Press any key to boot from CD, simply do so.
Even though it goes through some preliminary installation steps, you will eventually be prompted to choose the option for manual repair (press the R key).
This installs the Recovery Console.
Type the administrator password to log on to your installation. Then, at the command prompt, type FIXMBR and press Enter.
If you receive a message saying that there's an invalid boot record already in place; simply confirm that you want to continue. Reboot, and you should have your old Windows screen back.
If you simply cannot access your hard drive, try removing it and connect it to a USB adapter and see if it can be read by a secure PC.
Olympus VN6200... | Answered on Aug 08, 2014
You can recover deleted files with asoftech data recovery software. get the software from link below
Voice Recorder Data Recovery Software
Please be noted that your voice recorder memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
You may check out this memory card recovery tutorial also
Olympus VN6200... | Answered on Apr 04, 2014
I was using my voice Digital Recorder VN-6200PC. I was recording a my lesson when the screen shows formatting, I immediately took out the battery as not to lose any data, because I was taping and it began to format and I lose the data I was recording. So this time I remove the battery. However when I put back the battery it began to say imput blocked. Please help?
Olympus VN6200... | Answered on Nov 30, 2013
If you installed it in your computer you should have the eact copy of the file, manula and system. Should be possible to format the memory from device menu and then copy the filesform computer over to the recorder.
Olympus VN6200... | Answered on Nov 12, 2013
You can take the memory card out from digital recorder, and then connect the SD card to computer with a card reader, you can then follow this guide to recover your files
SD card data recovery guide
Olympus VN6200... | Answered on May 12, 2013
The customer had problem in recovering deleted files from his digital voice recorder. I have advised him to any data recovery tool. He was not sure about how to select the digital voice recorder for data recovery. I have shown how to select the drive in his laptop.
Olympus VN6200... | Answered on Aug 12, 2011
Sounds like you have lost your operators manual....go to www.olympusamerica.com to download.
Olympus VN6200... | Answered on Nov 17, 2010
So what is the problem??? ... if you need a manual go to www.olympusamerica.com
Olympus VN6200... | Answered on Oct 14, 2010
The headphones may have a defective connection or failed completely.
Olympus Audio... | Answered on Oct 03, 2019
Olympus VN6200 Digital Voice Recorder Logo
24 questions posted
Top Olympus Audio Players & Recorders Experts
Ekse
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Olympus Audio Players & Recorders
Most Popular Question
  • Audio Players & Recorders
