Panasonic KX-TG1033S Cordless Phone Logo
Posted on Feb 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic KX-TG1811AL Digital Cordless Phone
Hi - I have just purchased 2 of the above units and added all my entries into the phonebook of one of the units. However, the Operating Instructions do not appear to advise how to synchronise the phonebook for stored numbers from one handset to the other. Could someone please advise if this is possible to do and if so what is necessary. Sincere thanks for any assistance. Bryan
  • Anonymous Jan 26, 2012
    My problem seems to be the same as yours, I hope this problem can be straightened out. THEY DO NOT ACCEPT PHONE CALLS FOR TECH SUPPORT.
    Does anyone have a phone number for the Panasonic Tech Support or question to answer for fast fixes. Model # KX-TG6643
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
549
Points
I tried opening a 'GROUP' WHICH HOLDS 50 NAMES AND PHONE NUMBERS- there are two groups, #1 and #2 - each holds 50 #'rs for a total of 100 numbers.
once you have listed all your numbers, the will log into the hand sets.
To open the list Press the left soft key, then Group soft key, Select group one, with the middle soft key, and you numbers will appear.
GOOD LUCK, IT WORKS.
john milligan
Level 3:
  • Master 514 Answers
  • Posted on Feb 22, 2009
john  milligan
Master
Level 3:
Answers
514
Questions
Helped
214592
Points
1307
Sorry, it seems that they have no manual for this model online yet, however, if you go to page 20 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") that procedure may help. good luck!
1helpful
Is there 3 way calling on this model?
[PDF]Operating Instructions - Support - Panasonic
service.us.panasonic.com/OPERMANPDF/KXTG2740S.PDF
PanasonicModel No. KX-TG2740S ... other cordless phone. For Best Performance. 3. For assistance, please call: 1-800-211-PANA(7262) ... •If you use the handset near anothercordless phone's base unit, noise may be heard. .... 2-Way Radio Communication .....&Each mailbox icon will flash if there is at least one new message in the.
Panasonic Product Support - KX-TG2740S
shop.panasonic.com > Get Support
PanasonicObtain product support for Panasonic KX-TG2740S 2-Line 2.4GHz MultiTalk Expandable Cordless Phone System with Digital Answering System.
Why did I suddenly lose my entire phonebook?
service.us.panasonic.com/.../KXTG6431-MUL.PDF
PanasonicJul 15, 2009 - service offered by your service provider/telephone company. ...Expandable Digital Cordless Answering System .... KX-TG6431 series .... To prevent severe injury and loss of life/ .... you erase information such as phonebook ...... the ringer volume is turned off, ~ is displayed and the handset does not ring.
Can you speed dial on the Panasonic KX-TG4011?
This model doesn't have a speed-dial or one-touch dialing feature. It does have a phonebook feature that allows you to store up to 50 phone numbers, and you can select an entry and the phone will dial automatically. Not quite the same, but it's all that's offered. The manual gives the steps for entering names and numbers into the phonebook, and for selecting and dialing an entry.
I lost the manual for My KX-TGA641T cordless phone(s) and cannot figure out how to make phone book entries. I would like to download that part of the manual if possible. George Erickson
Are you interested in adding a new entry from scratch or from a Caller ID record?
To store a Caller ID record, with the handset in standby mode, press Menu # 2 1 3 (keypad digits). Use the up/down arrows to locate the incoming call information. Then press Edit until the phone number shows up in the correct format to dial the number. Then press Save and use the up/down arrows to select Phonebook. Then press Select. Edit the record if needed. (Save, Select and Edit are softkey options so check your screen for the button positions.)
I'm not sure how to enter a new record for the directory.
Panasonic has the manual for the KX-TGA641T at their support site: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/DECT-6-0-Phones/model.KX-TGA641T . Click on the Operating Instructions tab. The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/KXTGA641.PDF . Since the handset is compatible with several base units, you may want to search for the manual for the base itself. Start here: http://www2.panasonic.com/consumer-electronics/support and enter the model number. However, I didn't find a specific record for the base for a couple of the bases that I tried.
I hope this helps.
6helpful
Need to delete phone entries in the Phonebook
Hi. Not sure if this will help but on my Panasonic cordless phone (different model to yours), there's a button labeled "mute/clear" which is used to clear text when entering text for phone entries. Well, if you scroll through you phone book to the the entry you want to delete and then rather than pressing "Edit", press "clear" and, if it's like mine, it will ask you if you want to erase the entry, and you press "yes". Hope it works for you.
1helpful
How to add calling card 800# and PIN to expedite LD calling.
When storing a calling card access number and your PIN in the
phonebook as one phonebook item, press {PAUSE} to add pauses after the number and PIN as necessary. Or, if stored as separate entries, during a call, press MENU, press 1 to select “Phonebook”, and scroll up or down to find the entry and press Call. Repeat to dial other numbers.
Trying to use multiple base units
It is not possible to set up 2 base units to work with same handset as the base unit and the handset are tagged by their operating frequency, which also works as the privacy filter for the user, so that your neighbors cannot pick up your line and use on your expense. For your requirement you need a DECT system that can support multiple base stations.
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
