Won't connect to facebook through router
SOURCE: Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
SOURCE: I bought a NOOK from barnes & noble. I
Welcome to Fixya. The security key or password can be found when you access the wireless settings page of the router. To access the router page you need a working computer that is connected to the router. To access the router page just open a browser then type 192.168.2.1, the Default password is blank.
Click on Security under Wireless and look for the Security Key or Network Key (Passphrase). You can also personalize the network key if you want to.
You can also refer to the screenshots below.
Manual can also be downloaded on the link below. Just browse down on the page to and click on the link to download.
Belkin F5D7234 Manual
If you have questions please let me know. Thanks for using Fixya.
SOURCE: Hello, I do not know much about troubleshooting
Thank you for using fixya.
Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Hope this information is helpful
SOURCE: My Belkin F5D8236-4 v3 Router
Me too my belkin surf wireless router f7d2301 v1 suddenly turns off and i can't turn it on
SOURCE: After resetting my Belkin Wireless Pre-N router I click submit to login belkin router I get
Still not reset. Hold the reset till it cycles. A simple push only restarts it. You have to hold it in while power is on.
The same thing is happening to us. We cannot connect to Facebook with any computer and the same router. Interestingly enough, I can connect to FB if I go directly through the modem. I've hard reset the router and changed my IP through comcast. Strange that its the same router.....
I figured it out. The "firewall" enabled on the router blocks facebook. Disabled we can get through.
