Check what head gasket was used . I suspect that an after market gasket was used. If that is the case there will be holes in the block and head thet have no matching holes in the gasket thereby causing the problem
Was the water pump changed the impeller on the inside is plastic and can crack over time and break up
SOURCE: ford bantam rocam 1.6i speedo,temperature gauge and rev counter not working
Sometimes when the batery of vehicle goes flat or when u fit a new car batery to the bantams they love to give that problems like gauges not working rpm not working speedo not working and cluster display is dead, u disconect the batery termanils and for example fit positive termanil and arc. Or short til that blue spark occur then u swop around negative on and arc positive,leave the ignition switched on arc til gauges move!! Don't ask me why but that happend to me! A autoelek friend of mine showed me this! NB don't tri this with vehicles with a lot of elektric featers it can cause demage to ecu (engine control unit)
SOURCE: overheating on ford bantam
there are three probable causes that may result to overheating one inadequate circulation of coolant within the cooling system. The radiator is clogged with dirt some stems are closed.try to flush the radiator using rad flushing fluid. Second improper bleeding of trap air within the cooling system. Third the water pump blades are worn out inadequate circulation of coolant.
You should probable also check the water circulation i.e. water pump, radiator, thermostat, heater control valve etc...
