My copier is working first copy while i turn it on but for second copy displaying scanning and it is remain on scanning without work
SOURCE: I want to direct print from computer
I would like to print direct from my computer and the problem am facing is usb connection.I do not have the software to use in order for me to use and print. is it possible to down loard the software for canon copier IR2016J .KINDLY ADVISE.
Email: [email protected]
City : kitwe
Country Zambia
SOURCE: Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
SOURCE: we have canon copier ir 2016j, it started giving
Error code E007 on an ir2016 means that the fuser film has a fault. The fuser film is the black sheet that melts the ink into the paper on the final stage of the copy process. It more than likely has ripped apart. You will need to call a service tech for this one.
SOURCE: canon ir 1600 my copier print copy image is very poor
iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
Use GENUINE CANON DRUM UNIT and GENUINE TONER.
SOURCE: canon ir 2016j downlodstandby problem
u have get ur machine loaded with newer version of system software by a rep.it requires SST (software service tool)
