Question about Dell Inspiron 6000 Notebook
Dell inspiron 6400 screen problem
Hi there!
I Have Dell laptop INSPIRON 6400 for last 3 years and recently I have problem with monitor. No image on it only vertical lanes, back light working ok so screen looked to be white. I connected external monitor and laptop works ok, so I replace screen and that didn’t fix problem then I replace video cable and still no joy, at this stage I’m running out of ideas, didn’t try replace inverter back light working ok so I don’t its inerter can inverter effect image on lcd? Any chance you can help me my warranty expired, please help Val
  • doh h Jan 12, 2009
    Hi !
    I don test like you set and that what I get
    LCD test
    LCD connection ok
    LCD inverter ok
    LCD Graphics test error Code 0334
    Msg Error Code 2000-0334
    Thanks Val
I had the same problem. You need a new graphics card.
Posted on Jan 29, 2009
HI
Please run a diags on the system by pressing FN+power button and posts the results. Also try booting to safe mode by pressing F8 when you start the system posts the results, I will be able to definitely help you with this.
Thank you
Rakesh
Dell Laptop Expert
Posted on Jan 09, 2009
  • Anonymous Jan 14, 2009
    with the error code what it means is that, when the "do you color lines" i believe either u dint press y for yes or press n for no or did not give a response. does the screen looks fine in the diags??? if it looks fine its an issue with your operating system.
    try to boot to safe mode and check??
6ya staff
SOURCE:
A thin vertical blue line has appeared across the screen of my Dell Inspiron 6400 laptop. How do I clear it?
A simple way to check also is to hook it up to an external monitor and see.
plaese tell me after chacking.
Sep 10, 2010 | Dell Inspiron 6400 Notebook
My laptop monitor goes dark
Hi there! Try this trick...
You can adjust the screen brightness within BIOS set up...
It works with Dell!!!
^_^
May 13, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 screen won't go 'full screen' on pinball (running XP Pro)
Hi Dominic
You need to buy a new computer, a Mac ideally.
A possible work-around for the 'not going full screen' problem would be to sit much closer to the screen, making the images appear larger.
If you could get hold of a magnifying glass from ebay this may help too.
Oct 23, 2009 | Dell Inspiron 6400 Notebook
Replaced inspiron 6000 screen with 6400 screen
the screen is bad just look for something to do about it.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron password fault
Hi my inspiron 6400 cannot boot up after trying several time .I press switch on, then after 3 second it goes off again.Battery fully charge.
1)battery new
2)rep used mother board
3)rep touch pad
4)rep keyboard
I hope anyone that know this fault .Kindly help me with the issue.
Mar 08, 2009 | Dell Inspiron 6400 Notebook
My Dell Inspiron 6400 is extremely dark. +brightness does nothing
Hi there.
Yes, if you can see a very faint image on the screen that indicates that the inverter or inverter coil has become defective and needs looking at or replacing.
Good luck and thanks for using Fixya!!
Feb 19, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Inspiron screen wobble
image wobbling, or lcd wobblings, please?
Feb 28, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6000 Notebook Logo
1,505 people viewed this question
Ekse
Clive
Clive
Alun Cox
