My note book is completely locked and i have to change the ip address for a new ethernet connection, my uncle forgot the password. now can i change the os with same drivers with xp windows pls help me out..
Don't get worried when you lost admin password. I know a quick method to recover windows login passwords, it need no computer skills and no reinstalling windows. Google Windows Password Seeker or http://www.passwordseeker.com/howtouse.html Hope this helps. Enjoy!
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password, but you forgot administrator password, that way doesn't work. you must use software to recover administrator password. This method is very easy. You can go to this site http://www.reset-windows-password.com/how-to-reset-windows-password.html
There is an easy way to recover Windows Passwords required no reinstalling Windows OS and no computer skills. You can download a windows password reset tool on the internet. It can reset Windows login Passwords. You could get back into Windows just within few minutes. I recommend this site http://www.reset-windows-password.com
Lost windows passwords isn't a big problem. I realize a fairly easy method to recover lost windows login passwords, just need to create a bootable CD/DVD or Usb stick to reset lost windows password, I have made a bootable CD with the utility Windows Password Seeker and reset my admin password successfully. You can Search windows password seeker or visit their site: http://www.passwordseeker.com
If u have problem inlogin password in win xp then when u power up pressF8 key to login in safe mode.
then clik on administrator
then reset your password.
but if u have bios passwqord problem then u have to rset your bios settings.
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Step 1:
Step 2:
Step 3:
Windows XP
Windows 7
Related Articles:
Step 1:
Step 2:
Step 3:
Windows XP
Windows 7
Related Articles:
