SOURCE: Ice Maker Issues
HELLO!!!
THIS MAY HELP U ...
http://www.applianceaid.com/icemaker.html#overflowing
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
SOURCE: water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
SOURCE: evaporator freezing up on my ge gss25tsrd refridgerator
YOU CAN SEE HEAVY FROST ON THE REAR OF FREEZER WALL?
SOURCE: fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
These days, modern fridges come with automatic ice makers that are built into the fridge itself. The fridge automatically fills the ice holders with water that then freeze into cubes. You can then tip the ice onto a tray that is removable and then the fridge will automatically re-fill.
The Model number for my GE refridgerator isGSS25JETC BB, it still makes ice the nozzle where the water comes out freezes up and the prsseure will pop the frozen ice off and the water runs into the ice tray but it freezes up each time
