20 Most Recent
GE WR30X10093 Refrigerator Icemaker Kit Questions & Answers
Troubleshooting a GE TPX24 icemaker
Simple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=>
WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=>
WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks
Sea Breeze
Ice maker not making ice
check the compressor if its running or not if not check its low pressure switch may be the unit is lack of refrigerant or if this one have a PC board change it maybe the old PC board is not functioning thats why the compressor is not running
GE TFX24E side by side refrigerator, ice maker
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Icemaker wont harvest
if you press the arm that slides out to feel the ice all the way in three times within a few seconds, this should start a harvest cycle. If it does, then you know it can cycle and you have a temperature issue. your ice can freeze even at 25 degrees, but it won't harvest unless it is getting to about 8 degrees or colder, so check the temps in the freezer
