Nu Mark AXIS 9 Logo
A
Anonymous Posted on Oct 18, 2012
To replace cd drive on numark axis 9 do i need some welding to do?
Its welding required to install a new cd drive on a numark axis 9
4 Related Answers
Anonymous
  • Posted on Sep 07, 2007
SOURCE: Parts for numark axis 9
Yes You can get them from Instrumentalparts.com aka www.numarkparts.com
Anonymous
  • 17 Answers
  • Posted on May 05, 2010
SOURCE: I have a 'Numark Axis 9' DJ standard CD player.
You will most likely need to replace the CD drive. I believe the OEM part is CM-H90. Only 8 screws to complete this task.
Anonymous
  • Posted on Dec 23, 2010
SOURCE: my numark axis 9 does not read cds, wot do i do
not reading my cd's it just keep saying no disc''
Anonymous
  • 12 Answers
  • Posted on Mar 22, 2011
SOURCE: i need to replace a
it can replaced...give it to good repairer...
Why axis 9 smell burnt
Output IC might be damaged. Seek tech support.
Want to connect my nu mark axis 9 to my computer by using virtual dj
Hi gregory_fils,
Please read the manual which came with your nu mark axis 9 to see if it is compatible with your computer if so, there should be instructions in the manual.
i hope this helps.
I need to replace a numark axis 9 cd mechanism
2helpful
2answers
My axis 9 wont play burnt cds
nice decks, try puting your cds on a differnt format like....mp3,mp4.avi, ect...
Problem with numark cdn 88 disk loads but does not read
my best suggestion, if it won,t read any discs then it need repairing. go through your newmark retailer .they can normally get it fixed by numark. newmark players do go this way unfortunately. if it happens again ,don't buy cheaper models in future. i have had numreous problems with numark axis 9 cd players and in the end i replaced them with a different make.
6helpful
4answers
Problem with numark axis 9!!
Hi, I’m from Yucatan, Mexico. I’ve always used Numark cd players, I have two Axis8 and two Axis9, and one day I had the same problem with an Axis9. I know a little bit about electronic so I opened the machine and began check it, I took the decision to change and electronic part, I took it from the another Axis9 which was working perfectly, this part is the memory, buffer, effects and it controls all the front panel, jog, play, pitch, etc. I discovered the problem, this electronic circuit part was wrong, I thought that it was impossible to repair so I began to investigate. I visited Numark web site, they sell any electronic part you need, I bought a new one from Numark Company for 200 dollars, and this is the most expensive. They sell parts for Dual Players, Axis, CDX, Mixers, etc. If I not wrong you need this part, now it costs 174 dollars: TWPC01C04603 PCB, Effects/Buffer - Axis 9 (Red) | I got it and my Axis9 works like new again!!! Good luck with yours!
2helpful
2answers
Numark address in the UK is: NUMARK UK LTD UNIT 9, THE CHRISTY ESTATE IVY ROAD ALDERSHOT GU124TX UNITED KINGDOM Tel: +44 1252 341 400 I would give them a call. Please update the question & let us know if the information given was useful to you - Good Luck!
Top Nu Mark Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
