20 Most Recent
Nu Mark Numark Cd-Mix-2 Dual CD Player/Mixer Combo - Good CD Player Questions & Answers
Numark icdmix2. Jammed cd's
Power cycle while holding eject button?
This unit should still be covered under warranty. I would contact Numark for an RMA.
It does it on both decks..If it was the volume
I don't know how you are using the mixer are you using it as an interface? or are you directly running speakers to it? start with checking speaker cords I had an issue once that I accidently grabbed a mic cord and used it every system is different but on mine it cut input to all my speakers till right cord was replaced with good one if that's not it give me alittle more info on how your using it before I can touch on it further good luck
Can i connect my laptop to my numark cd 2
Yes, you just need the appropriate cables. The simplest being a 3.5mm jack to phono to make a direct link tween your laptop output and one of the two channel inputs. Then you simply choose phones on your front end (whichever channel you plugged into) and away you go.
