As soon as I turnr on the printer I hear a loud squeak like rollers or gears are turning and are dry. It also makes this noise when it is printing.
With squeeks its a trial and error process. 1. Turn machine off/on and see if the noise is there on startup If the machine is there on startup try this 2. Remove paper tray, remove drum/toner, close up the front panel 3. Restart the machine off/on If thr noise is still there means its a mechanical part inside thr machine, if the noise hase gone then try this 4. Put the paper tray back into the machine turn off/on if the squeek comes back then its the tray that is the problem. If there is no squeek still then its going to be the drum and toner causeing the squeek
Tried that and still squeaks
Perfect advise .. it was the Drum
Perfect this was so helpful! It was the drum
It most likely has parts that are worn out and need replaced. you will need to have it serviced.
SOURCE: clicking noise with MFC-8640D
Make sure that the paper guides in your paper tray are not holding the paper too tight against the front of the tray, there should be about 1/16 inch play so that the paper can be lifted to the roller easily. Also take out your toner and drum and turn it on, if the grinding noise is gone you may need a new toner, some refilled toners are too tight to turn properly.
SOURCE: HL 2140 does not print
This is a common problem to your brother printer model 2140. You need to turn off your printer and take out the toner. Look for the side and you will see a small hole on both sides. This is the sensor. You need to cover it with electrical tape.
Here is a detailed video on how to do it:
http://www.youtube.com/watch?v=hPCGZZIdXyM
Good luck and hope this helps you.
Testimonial: ""Thank you so much! it saved me valuable money!!""
SOURCE: HL 2140 page printing all black
Dear sir, I know what is problem? your toner cartridge is demage please change it also you re-install your old toner then quickly take a decission
Thanks
xptareq2000
wiz
all the best
usb
