I have installed a prostart remote starter model ct-3271 in a 2002 sonoma, I programmed the remote and the truck started remotely 6 times, now it won;t start with remote. Had to Program truck to start with key and had to do this reprogramming a few times, now truck will start with key, but will not start with remote ,,cranks over Wants to start ,we adjusted the Time Delay Adjustment in Virtual Tach System ,,,after trying with remote start still get no start ,tried with key right after remote start and still no start,so had to adjust the Multi speed Tach Programming to start truck with key, Checked wiring connections all ok, Security light comes on and flashes this is intermitent,Check engine light is on now,
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
SOURCE: Remote start installation problem
If you have the Manual There May Be A "TIMER Setting for RUN time . I have Installed Some that Do Have this Feature
SOURCE: need install manual
http://www.engines911.com/asdocs/CT-3200_ig_en_h370s380v150_040902.pdf
copy and paste into your browser... should be able to download and print...
SOURCE: I have a remote starter
http://newrockies.ca?ap_id=judd0081
----- With this fix, you can take that whole Vats, passlock, passkey garbage system out of your car all together. I know it seems like a risk at 200 bucks, but seriously i had no happier day than when i finally got that thing out of my car. I'd been dealing with a "sometimes starting" car for a year. Trust me, this exactly what you need. They have a 100% money back guarantee+shipping, a support line, and pictured instructions,I couldnt be happier and i KNOW this will help ya. Took me about 45 minutes to locate the part in my car, and 10 minutes to install the bypass. LOL
Eliminate it, instead of using that resister as a bandaid
well I tried and want to know how I can remove the check engine light, how can I power up the second ignition white wire ??
and is the white wire in the wiring harmess,,and what voltage is it. is it a thick or thin wire,where in the harness is it..
It's the same guage as the 1st ignition, in the same location with same voltage.
the only white wire I found was in the harness connected to a white plug and the white wire had no power to it,and no one here could answer my follow up question, so I connected a green wire I found from remote and connected to white wire in harness and have power to white thin wire when key turned to on to start truck,but still have check engine light on,when key turned to off no power to white,,,can someone tell me how to get the checkengine light off,I scanned for codes and found that 3 codes I got were all for transmission and I need 2nd ign,wire, does anyone here know if the 2nd ign wire is a different colour in a 2002 SONOMA WITH 4.3L engine,found 2 wiring diagrams and they have diferent colour wires in the wiring harness,other colour for 2nd ign, says might be brown, could this be possible different coloured wires for different size engines,really need to get truck running thanks
