I have cleaned all filters, valve, spray arms, drain pipe etc. When I fill the dishwasher, the drain/inlet light flashes after a short while. When I have just the trays in the dishwasher without any dishes or cutlery in, it runs absolutely fine. I have checked that spray arms do not touch any dishes and that the dishwasher is not overloaded.
SOURCE: Wash motor does not run: Inlet/Drain error
Wordhog: Does sound like a siezed wash pump to me. Wash motor needs to run to get the correct level of water.
To drain a Miele dishwasher, start the machine on a cycle. All the Miele range of dishwashers drain before filling. Then hold in the start button until the end/finish light is lit. Keep doing this until all the water has gone. You could just get a jug and bail it out. Once the jug does not do the job anymore, switch to a cup, I use a very large syringe for the remaining half a litre.
SOURCE: inlet/ drain light keeps flashing
You have a leak and the bottom pan is full of water. You can remove the cover at the bottom front of the dishwasher and see if the bottom pan is filled with water.
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
SOURCE: Inlet/drain light flashes on miele dishwasher and
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
SOURCE: Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
