20 Most Recent Miele 24 in. G646SC Plus Free-Standing Dishwasher Questions & Answers
I had the same problem a few days ago. I followed the instructions to clean the filter and check to see that the impeller was free to rotate in both directions. The problem persisted. After reading this thread, and a similar one on another site, I tried what mikeboerma suggested in "solution #3", and bingo, problem solved. The magic combination is to push and hold the on/off button and the start/stop button.
Miele 24 in.... | Answered on Jun 28, 2019
You would need to look at the wireing diagram and find out if there is any thermostats that I'm sure there are. You would need to find out if they are working properly.
Miele 24 in.... | Answered on Mar 11, 2018
The dishwasher must be removed from the counter so you can gain access to the pump. I would check with a parts supply company first to see if the pump is still available, and the cost. It may be too expensive to repair a dishwasher that old.
Removing the dishwasher is not very hard. Turn off the electrical breaker. detach the DW from the counter. Pull out. disconnect the water supply and drain. disconnect power supply if required.
Miele 24 in.... | Answered on Nov 28, 2017
be a part of human
Miele 24 in.... | Answered on Apr 09, 2017
I have the same problem on a Miele G647 SC Plus. It starts and completes the wash cycle, might skip a final rinse - not sure, but it drains the water. Pump then continues to run for extended period then inlet/outlet light comes on. The dishwasher never moves to the drying cycle.
I cleaned all filters, checked supply/drain hoses + the non return valve. All seemed servicable. But no real improvement in fault.
Any way I can fix this?
Miele 24 in.... | Answered on Sep 14, 2014
you need to remove the front of the door.there is a small pipe from the dryer fan to the top of the detergent dispenser. tis usualy gets blocked at the fan end. also the spout from the fan. this happens if you dont rinse loose food of the items you put in the dishwasher.
Miele 24 in.... | Answered on Jul 27, 2014
Try powering off the machine using the main power switch for at least 10 seconds, then power back after holding down the top solo and start/stop simultaneously.
You may need to check the drainage pipe and water inlet for blockages. Under the filter inside, you can remove part of the drainage system by removing the silver clip and pulling on the plastic segment.
Wash this through, it has a lovely ball bearing inside, but don spend too long wondering how big it is. Big it is.
Check the tubes, for kinks etc... Always disconnect the water supply before detaching the inlet, and be prepared for a mess, if you do decide to remove the drainage outlet pipe.
Failing this, the following post may help:
Check out this solution to the Miele 24 in G646SC Plus Free Standing...
Miele 24 in.... | Answered on Feb 28, 2014
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
127 questions posted
Top Miele Dishwashers Experts
mpservices
Archie Ferrarini
Archie Ferrarini
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Miele Dishwashers
  • Miele Dishwashers
Most Popular Question
miele g646sc plus dishwasher drainage
  • Dishwashers
