either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Hi, If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
the chances are the top oven thermostat has gone and may need replacing. also check on any selector switches relating to the top oven unit they can burn out on the contacts. there is no seperate fuse.
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
