For your interessting:
Strange:
I disconnect the HDMI cable from the Vu+ Solo2 DVBS2-Satellite-Receiver, and the HP Photosmart C309a "rings", and show this error message.
Two completely different Systems without any connection.
Note: Actually I use a rolled ~10m-HDMI-Cable between Receiver and TV, and the Printer is only connect to the Computer with a slightly longer USB cable, loose lying on the desk.
And, in this Printer, actually there is not a print head (But that does not explain this strange error).
FYI:
I disconnet the rolled ~10m HDMI cable between sat receiver and TV, and the HP Photosmart C309a "rings" and show this error.
OK, actually in this printer is not a print head.
But that does not explain this strange error.
These are two completely different systems without a connection o_0. *spooky*.
The printer is only connected with a loose ~5m cable on the desktop.
SOURCE: Try to print but: get General Printer error 0x61000f6 beware spam number 1*800*532*4187
Hi
This error comes due to carriage jam. Turn off the printer and unplug it from wall socket. Now, remove the cartridges and check for any dried up ink residue on cartridges on inside the carriage. Clean the cartridges contacts and carriage using a Q-tip dipped i alcohol. Let the carriage and cartridges dry before you plug in the printer.
Install the cartridges and check. If it still shows error then unplug the power cord coming to the printer without switching it off. Now, remove the rear door of the printer and check for any paper jams over there, remove if any. Wit for at least 15 seconds and plug in the power cord. Now check whether it is working.
Daniel Scott
Testimonial: "Thank you very much for the information. very helpful. I am sure this information will help other people as well. Thanks again. "
