SOURCE: Unable to connect calculator to computer.
Try opening the software on your PC. Set the connection to USB and connect your calc. On the calc press the right shift key followed by the right arrow key.....software should now recognize the calc.
SOURCE: HP 12c cALCULATOR
It is not calculating because your decimal point and the digit separator (that's the comma which automatically displays for every group of 3 digits) got messed up. To clear, turn the calculator OFF, then press and hold down the dot (that is the decimal point symbol) key while you press the ON key..
t
SOURCE: TI-83 Plus calculators won't turn on despite the many attemps...
It is possible that the contrast is too light as to make the cursor invisible.
In that case you can increase the contrast as follows:
1. Press [2nd] key , then release it.
2 Press [up arrow] key ,then release it.
Repeat the two steps until you get the right contrast.
To decrease the contrast, you press the [down arrow] key instead of the [up arrow] key.
Hope it clears the obscurity.
Hope that
SOURCE: Hi i have a problem
101.26 is what you'd get for 5% APR compounded monthly for three months. 115.76 is what you'd get for 5% APR compounded yearly for three years. Make sure that the compounding interval and the interest rate are consistent.
SOURCE: I have a HP 10bII
You can use the I/YR key on the top row to enter/calculate the interest rate.
We can't tell whether your numbers are correct or not without seeing them. Could you post the problem?
