Cars & Trucks Logo
Dana Ruth Posted on Mar 04, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2003 new beetle radio won't play! The screen shows the radio station but won't play out loud. The cd and cassette player still works. I've replaced the fuse on the back of the radio. But w
toddgilbert
Level 3:
Top Expert:
  • Volkswagen Master 6,360 Answers
  • Posted on Mar 09, 2018
toddgilbert
Volkswagen Master
Level 3:
Top Expert:
Answers
6360
Questions
5
Helped
1526727
Points
27737
Go to www.reliable-store.com you will get all info and
solutions there definitely
5 Related Answers
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Jan 31, 2009
SOURCE: 2004 Volkswagen Beetle Radio/CD player
new one with a usb connector and sd card reader is better and cheaper
Anonymous
  • 11 Answers
  • Posted on Jul 09, 2009
SOURCE: 2005 Volkswagen Jetta TDI replaced the battery,
did u install all wires back might be missing either neutral white wire or ground green wire for radio or
Anonymous
  • 510 Answers
  • Posted on Jun 19, 2010
SOURCE: Fuse 42 radio system blows immediately after
Does fuse blow as you switch radio on/or radio still off
Either way ,remove radio,check connections for damp ingress
To remove radio go to fitaudio.com
Anonymous
  • 10 Answers
  • Posted on Aug 18, 2010
SOURCE: My radio on my 2001 Volkswagen Beetle is not
does either safe or 1000 come up in the display if not there is a fuse on the back of the radio i would check it first
Anonymous
  • 1874 Answers
  • Posted on Jun 21, 2011
SOURCE: Cannot get radio to work
The sequence of VW radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
Radio display panel doesn't light on 2001 Ford Explorer
Pretty common problem for this era Ford radio. Easiest way to solve this problem is to install an aftermarket radio.
Used isuzu radio/cd/cassette will not work in my vehichle, does it need a code?
If it works @ all it doesn't need a code - it's a bad CD player.
td
Radio in 2003 jeep grand cherokee does not play cd's. it plays the radio stations, volume works, but it does not eject the cd or even recognize it .
you can look for a radio shop to repair the cd player it would be cheaper to install a aftermarket radio they do have kits if you have steering wheel controls
2003 Jeep Liberty - no radio sound after replacing the battery
Check all fuses inside and outside of the jeep and also try to disconnect the battery for 3-30 minutes and then hook it back up,and make sure if you have an alarm that its turned off.then try and see if it works then.Remember and try not to arc the battery terminal when you put it back together.
Cd stuck in 2004 VW Beetle
Soo easy just keep playing with it keep pressing the button the same thing happend with my mom and i got it out the way i told you.,DO IT WHEN YOU CAN!! :)
8helpful
3answers
My radio/CD player constantly says "ERR" and CD's won't play anymore. It doesn't show the time or the radio station either, just "ERR". I can hear it, like it's trying...
HI lisasmith566 IT is not a fuse problem .
the problem is your the CD part of the radio
must likely the cd is stock or more likely the cd drive motor is defective .
FIRST try pushing eject on radio and see CD comes out if not you need a new radio .
good luck vote
3helpful
2answers
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
