Have a echo srm 210 an old one. Rebuilt zama k 75 carb . I cant get it to rev up right it runs for 2-3 minutes and dies like it out of fuel. it won't restart unless to choke is on. how do i adjust the jet on it ?
SOURCE: Craftsman 25cc weedwacker (358.791030). Zama
need to adjust the high sscrew. i do mine in 1/4 turns. start machine, full throttle, adjust the h(high) til it clears up.i would start by turning 1/4 counterclock wise, just remember to keep track, in case it runs worse, the put it back to orig. then try the other way. but i suggest 1/4 turn at a time
example... think of a clock when turning screw. straight up and down, 12oc, 1/4 turn will be 3oc, another 1/4 will be 6oc, and so on. hope it helps!
SOURCE: 99 model Harley Sportster 1200,
Hi Shaun, the only thing I can suggest is you may have a tight valve clearance, sticking valve or broken valve spring. Regards Phil.
