20 Most Recent Echo Hedge Trimmer Service Repair Manual Hc-160 7 Hc-200ae Kioritz Corp Repair Questions & Answers
0answers
Echo SRM-210 trimmer keeps releasing all of the trimmer line. I have tried replacing the trimmer head/spool but this did not resolve the issue
Sounds like there is something either broken,stuck or missing in the head.
8/1/2023 1:18:38 PM • Echo Garden • Answered on Aug 01, 2023
2answers
Stihl blower - full throttle it stalls out. low speed ok. have replaced fuel line, spark plug.
check your muffler screen for being plugged, this will cause it to not accelerate2StrokeJim
10/31/2022 10:18:08 PM • Echo Garden • Answered on Oct 31, 2022
2answers
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50 www.youtube.com/watch?v=uFN82KDj3a8 Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
10/18/2022 9:04:26 AM • Echo Garden • Answered on Oct 18, 2022
2answers
My echo srm 225 string trimmer line will not advance. Have rewound line and clear out grass from inside head.
Sometimes the spring may need extending as over time the bumping makes the spring lose its push tension causing no line advance
10/18/2022 8:53:57 AM • Echo Garden • Answered on Oct 18, 2022
Echo model GT-1100 where can i buy ignition coil parts number 15060142030 or samthink will be working with that model.
small engine repair in your area or online
10/4/2022 2:07:06 AM • Echo Garden • Answered on Oct 04, 2022
String keeps coming out of Echo SRM-225
is it possible you have wound string backwards? this is the usual case for string advancing string .
9/26/2022 12:24:32 AM • Echo Garden • Answered on Sep 26, 2022
Weedeater want reb up put new carburator 230 echo weedeater
I know this is a very old post, but figured I'd answer it so any others with this issue can have the fix. With Echo trimmers not revving to speed although they start with no problem, the issue is usually the muffler screen. It becomes plugged with carbon because of improperly mixed 2 stroke fuel. Remove the screen from the muffler and burn off the carbon with a propane torch, or wire brush it off. Once cleaned engine should rev to speed.
6/25/2022 4:53:50 PM • Echo Garden • Answered on Jun 25, 2022
Echo gas weedeater. Starts, runs until heats up - maybe five minutes - then won't start again.
Classic sign of coil failure. Run it until it cuts off then test the coil. Most likely 0 resistance, complete open circuit. This is common, coil can't be repaired, only replaced. It is a simple fix, and echo trimmers I believe are worth the cost of coil to repair. Plenty of youtube videos on how to do this repair.
5/30/2022 2:45:57 PM • Echo Garden • Answered on May 30, 2022
I have a newer 58v Echo trimmer. Worked fine last season, but when I use it now it runs for a few seconds and then completes shuts down. If I try again, it runs for a few seconds and stops again.
This appears to be a good news problem. There is an easy fix/work around! Consumer reports found the same problem that you have discovered. Holding down the check battery switch allows the unit to operate. Read the link around the sixth paragraph the story is told. Echo Trimmer Can Be Tricky to Start "Our testers discovered the fix by chance. Pressing the check battery button, a last-ditch attempt to get the trimmer working, made all the difference. While this button ordinarily indicates the battery's charge status, in this case it also served to keep the battery from switching into protection mode and cutting off power to the motor. The next time you fully charge the battery, however, the problem can reoccur." Hope this has helped?
5/18/2022 6:30:16 PM • Echo Garden • Answered on May 18, 2022
I have an echo pas-225 trimmer with New coil and plug will spark 1or2 times every couple of pulls with or without the Killswitch unplugged at the coil?
Set proper air gap. See following video (3:15).
https://youtu.be/05JYQ4s2Y_w
1/30/2022 12:27:37 PM • Echo Garden • Answered on Jan 30, 2022
6answers
So I replaced the carburetor, air and fuel filter, fuel lines, ignition coil, flywheel, carburetor gasket and clean the screen on the muffler, new spark plug and my Echo CS-400 chainsaw won't start
Air fuel and gas... It needs all of these Are the crankshaft seals any good ??? This causes an air leak, leading to the engine not being able to draw in the air/fuel mixture Check this by spraying carb cleaner into carb. Does it start ??? Did you check for spark ??? Did you set the coil gap ??? .010 Did you check compression ??? Someone mentioned 100psi. Close but most wont run under 90psi. Others need 120psi. Echo's will run under 90psi but not much lower Did you remove the muffler and check the exhaust side of the piston ??? Scoring will keep it from running but I have seen them run, albeit poorly but still run with major scoring. Is the spark arrestor still installed ??? Is it plugged ??? Just some of the tests I perform since I am an Echo/Shindaiwa Tech
12/7/2021 11:06:13 PM • Echo Garden • Answered on Dec 07, 2021
3answers
Here's a good one. Spark & gas, won't start.
The most common cause is a wood chip stuck in the inlet or exhaust valve. Check the compression.
12/3/2021 12:03:56 AM • Echo Garden • Answered on Dec 03, 2021
Gas mix ratio for echo srm-230
50:1
7/24/2021 9:47:26 PM • Echo Garden • Answered on Jul 24, 2021
Why does my echo srm 230 only stay idling when I have it turned with the carburetor facing the ground and if I hold it right it bogs out
Check the fuel lines. Make sure the pickup tube (line with the fuel filter) has not fractured.
7/16/2021 11:19:30 PM • Echo Garden • Answered on Jul 16, 2021
2answers
I don't know what fuel my leaf blower needs.
Almost every leaf blower uses gasoline mixed with 2-cycle mixing oil. Unless you have a larger, commercial model with a separate oil tank, you'll need to purchase mixing oil and mix it with your fuel. You can find mixing oil at PartsBuggy.com.
5/6/2021 5:12:27 AM • Echo Garden • Answered on May 06, 2021
Echo Hedge Trimmer Service Repair Manual Hc-160 7 Hc-200ae Kioritz Corp Repair Logo
1 questions posted
Top Echo Garden Experts
john h
Ngoro
vince
Are you an Echo Garden Expert? Answer questions, earn points and help others
View Most Popular
Echo Garden
  • Echo Garden
Most Popular Question
echo model gt 1100 buy ignition coil
  • Garden
