Sharp AL-1041 Laser Printer Logo
Jami Hendren Posted on Aug 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp AL-1041 Printer/ Copier will not power on
My Sharp Al-1041 Copier-Printer will not power on. No lights whatsoever. I read the manual. There is no fuse. All the doors are closed. I have unplugged the power cord and attached again. Tried everything I can think of with no luck. It was fine yesterday.
Anonymous
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 188 Answers
  • Posted on Aug 07, 2012
Anonymous
Expert
Level 2:
Cheetah:
Answers
188
Questions
Helped
88862
Points
384
Make sure you are not plugged in to an outlet controlled by a wall switch. Bypass any power strips.
5 Related Answers
Montgomery L?pez
  • 4 Answers
  • Posted on Jan 31, 2008
SOURCE: Sharp AL-1655CS Laser Printer stays in download Mode
you can´t. the only way to fix that is replace to main pwb. i have 3 whit the same problem.
Anonymous
  • 48 Answers
  • Posted on Oct 08, 2008
SOURCE: Driver for Sharp AL-840 Laser Printer
This site provides you access to the driver you require
-you will need to know your operating system (XP or 2000, etc)
http://www.driversdown.com/drivers/14637.shtml
hope this helps
Anonymous
  • Posted on Nov 08, 2008
SOURCE: Sharp AL 2080 Copier
There is a transparent plastic knob underneath the scanner unit that holds it in place while in its box. After installing you must turn clockwise this plastic to release the scanner mechanism. otherwise a L1 Error will appear on screen.
imaginguru
[email protected]
Anonymous
  • Posted on Jun 18, 2009
SOURCE: SHARP AL-2040CS offline after reboot
Official Sharp driver had set "use printer offline" setting in the printer properties context menu. After unselecting the "use printer offline", printer is printing again, even after reboot...
Anonymous
  • 154 Answers
  • Posted on Aug 20, 2009
SOURCE: I need the scanner/copier part of the driver CD - Sharp AL-1655cs
I'm not sure where you downloaded the printer driver but the Sharp website has a download link to the printer and scanner driver according to their website.
http://www.sharpusa.com/products/TypeSoftware/0,1086,20,00.html
What does an L6 error code on Sharp AL-1041 Digital Laser Copier mean?
Polygon mirror motor problem. Call or take the copier to your local dealer for repairs
tip
Sharp AL-1641CS Copier Manual Download
Free Sharp AL-1641CS Copier Manual Download
Models: Sharp AL-1632 / Sharp AL-1641CS
Would you like to review the features of the Sharp AL-1641CS Copier?
Have you lost your Sharp AL-1641CS Copier Owner's Guide?
Would you like a free digital, searchable, pdf version of the Sharp AL-1641CS Copier Manual?
Follow this link
(& click FREE) to download a pdf version of the Sharp AL-1641CS Copier documentation.
I hope that helps.
___________________________________________________
tip
Follow this link
I hope that helps.
5helpful
2answers
Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
http://www.sumthai.com/s0104/index.php?tpid=0086&pageno=1
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
Will not power on
Their's three possible solutions either the switch is defective , you have a Blown Fuse on your Power Board, or your power supply is bad.
System error L1-00 Sharp AL 1655cs
hi maryanne,delete all the sharp AL 1655cs programme and reinstall the printer software (INSTALL PRINTER) if need more help please log on to sharp copier web site for the manual instruction..before that make sure your printer is compatible for your PC.
3answers
Red Drum Replacement Light
If you saved the instruction when replacing the drum, did it give you a procedure to reset the drum count?
1helpful
Sharp al 1000 shows E and 7 and hangs off
if a number and alphabeth appears alternately The copier will not function. Turn the power
switch off, remove the power cord from the
outlet, contact any authorized service
representative for overall service maintainance
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
