2000 Ford Expedition Logo
Posted on Aug 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tail light is not lighting up in my 2000 ford expedition
My brake light and turn signal work,but my tail light wont light up when I turn on my headlights.Everything else works except for the right rear tail light.
bcharais
Level 2:
Sergeant:
  • Expert 278 Answers
  • Posted on Aug 05, 2012
bcharais
Expert
Level 2:
Sergeant:
Answers
278
Questions
Helped
123993
Points
790
Brake and turn are the same filament in the bulb. Try a new bulb. if that doesn't work your going to chase a short/ground on that wire back to the switch. get a wiring diagram to help.
5 Related Answers
Anonymous
  • 710 Answers
  • Posted on May 18, 2009
SOURCE: trailer signal and brake lights not working at back of trk
THERE SHOULD BE SEPARATE FUSES FOR THE TRAILER WIRES. HAVE YOU LOOKED UNDER THE STEERING COLUMN FOR THEM? IF YOU HAVE AND THEY CHECK OUT OKAY, THEN CHECK THE WHITE WIRE ON THE TRAILER PLUG, IT IS THE ONE THAT IS EXPOSED ON THE TRAILER PLUG. IT IS THE GROUND FOR ALL THE TRAILER LIGHTS AND THE MOST IMPORTANT OF ALL THE WIRES. SEE IF THE TRAILER HAS A GOOD CLEAN GROUND AS WELL(WHITE WIRE). HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
Anonymous
  • Posted on Oct 28, 2008
SOURCE: main brakes lights wont work
my brake lights do not work i have changed them and the fuse but do not work
1996 chevy silverodo
USfalcon
anwar alkhaldi
  • 197 Answers
  • Posted on Mar 15, 2009
SOURCE: Brake light/turn signal no not work on left side only.
check fuse number 7 in Engine Compartment Fuse Box , if its ok you need change turn signal switch
Anonymous
  • 1486 Answers
  • Posted on Jun 18, 2009
SOURCE: 2006 Ford Ranger. Rear passenger side tail light
Bad earth connection.Clean or replce wire.
Anonymous
  • Posted on Aug 06, 2009
SOURCE: Brake light, Turn signal not working rear right 06' Focus
I have a 2000 ford focus no brake lights. with the brake lights the transmission would not go into drive .replaced the brake light switch checked fuse replaced turn signal switch with no results then i moved onto the wiper switch and replaced it as much to my supp rise it fixed the problems
No tail lights or dash lights
If you have checked the fuses for those two circuits and they have power, the next step would be testing the headlight switch.
2answers
No brake or turn signals lites work on 2001 ford explorer sport trac
Power for the brake lights go thru the turn signal switch before getting to the light bulbs.
Do you have power in and out of the brake light switch and the turn signal switch ?
2answers
2000 Expedition: what is a multifunctional switch on a 2000 ford ex...
This is usually the turn signal lever which also has other controls built into it.
3helpful
2003 ford expedition tail turn signal light dont work bulbs are ok
You say the rear tail turn signals are not working are the fronts working? If the fronts work and the rears don't then you have a wire issue. Check the grounds for the tail lights or check and see if a trailer wire harness was put in by splicing the wires. Also check for brake lights and see if they work should be same bulb. If the fronts do not work either check fuse 18 in the fuse box should be a 10 amp or check brake fuse 2 which is a 20 amp
Turn signal and brake lights
these vehicles have a fuse for front and back turn signals. Check the owners manual where your back tail light fuses are located. It happened in my 99 expedition four yrs ago
I don't have any tail lights brake lights, and turn signals. i dont know what fuse or relay to check or replace, because I dont have a owners manual to cross reference. Oh my vehicle is a 1997 ford...
CHECK ALL LIGHT BULBS IN THE BACK. PROBABLY HAVE A FEW BAD BULBS THAT ARE BURNT OUT COMPLETELY. CHECK LICENSE PLATE LIGHTS ALSO. CHECK FUSES TOO TO MAKE SURE THE TAIL LIGHT FUSE IS GOOD.
Bulb only illuminates when i engage turn signal.
Hi: tail is on its own circuit and utilizes the longer thinner element in tthe bulb --- the brake and turn utilize the short thicker element in the bulb---- two different circuits. If bulb fails on tail ligh then the bulb is more than likely burned out. When you take the bulb out, look at the elements and you should see a broken thin filiment. bulb is bad, replace. good luck
2answers
2001 Explorer Sport ,Rear Driver Brake Light and Turn Sig. Broke
Rear lights are double filament bulbs one side for the lights other side for the brake/turn signals so it still may be a bulb. Do u have a test light or volt meter you can check to make sure u have power there when brakes or turn signals are activated. Or just try another bulb.
5answers
Main brakes lights wont work
I have the same problem and after a year of trouble shooting I have figured out that my third brake light the one on the top of the tail gate, the lens cover has a couple of cracks and water seeps in and my brake lights work, when it dries out they stop working because the water bridges the power to all the plugs.
So in order to fix this problem I ordered a new 3rd brake light from the ford dealer for about $180.00 as I was not able to find one at a junk yard or online, now my brake work. Also the new light comes with new plugs, lens cover and base so I guess it's worth it.
Check yours for a crack then uninstall it so you could see the melted plugs.
Good luck.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
