SOURCE: how do I set up the scanner on my hp officejet
What Operating system are you running? If you goto the "control panel" and click on printers and devices, the printer should appear. Right click on it, and select start scan. Go from there.
SOURCE: HP printer cannot find access point and I'm not sure what to do.
You must first connect your printer to the pc using usb cable, then run installation wizard that is on the CD that came with the printer.
Wizard will guide you through the setup orcess where you will provider your routers ssid (linksys) to your printer, and your printer will use that ssid to connect to your router.
After the Wizard setup is done, it will tell you to disconnect the usb cable and only then your printer will work on wireless.
Good luck,
Milan
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue
The Out of Paper
message appears on the computer and the product stops picking up or feeding paper.
Solution
Step one: Reset the product
Step two: Check the condition of the paper and reload it
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
NOTE:
Do not load too much paper in the product.
Step four: Clean the rollers
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
CauseAny of the following issues can cause the error message to appear:
SOURCE: Cannot coonect SCANNER (HP Officejet 6500 wireless) to my Windows
I have seen alot of problem/posts concerning HP AIO's and software issues. Typically some of the functions won't work or not recognized by solution center. Try a complete uninstall of all associated printer software, run registry cleaner if you have it, restart, then try completely uninstalling your Antivirus/firewall software. I have seen that just disabling Antivirus/firewall still causes faulty installations. Now, reinstall your printer software/drivers and connect cables only when told to do so. Some reason the AV/FW software blocks some of the AIO's apps from completely installing.
Hope this works...Good Luck!
SOURCE: how do you perform a
Partial reset:
Turn off the printer then disconnect the power cord at the back of the printer.
Wait for 20 seconds then press and hold # and 3 while reconnecting the power cord.
When the printer turns on, release both buttons. Try printing again.
FULL reset:
While the printer's power is on, disconnect the power cord at the back of the printer.
Wait for 1min. before reconnecting the power cord. If the printer did not turn on automatically press the power button.
Andy, The "chirping" noise happens frequently, at irregular intervals.
It could be an issue with the cartridges or the printhead. Open the lid and remove the cartridges then the print head and check for any damage or dirt. If it all looks OK the replace them (with same cartridges, doesn't have to be new ones). Now leave the lid open until the cartridges move back to their original place (could take about 15 to 30 minutes).
The same to my printer last night! At 3:30am! It scared me to death! First time that has happened. I've always had problems with this printer but anything like this before
My printer did the same thing last night! At 3:30 am! It scared me to death! I've always had endless issues with my HP 6500a , but never anything like this!
chirps even when unplugged
