I took the front cover off of the dryer. It is the drive belt. Thanks for your help.I took the front cover off of the dryer. It is the drive belt. Thanks for your help.
AnonymousApr 20, 2009
I opened the front cover however, the belt is not broken. What can the problem be, do you have any ideas. Please let me know.
ThanksI opened the front cover however, the belt is not broken. What can the problem be, do you have any ideas. Please let me know.
Thanks
You can't post conmments that contain an email address.
The first thing to check is the drive belt. you will need to turn the dryer on its side and look to see if the drive belt is broken. If this is o.k it will be the motor.
unless I'n missing something the water heater has nothing to do with your dryer. If you have an electric dryer and the tumbler is turning then you have electricity to the dryer. If however the tumbler is not turning check the wall plugin. It probably is a CFI plug and may need to be reset.
1. Disconnect the power cord of the Maytag Neptune dryer from the dryer electrical outlet. 2. Open the dryer door, and locate the four screws on the inside lip of the door opening. Use a Phillips-head screwdriver to remove the four screws. This will disconnect the front panel from the shroud assembly. 3. Grab the front panel on each side with your hands. Lift up on the front panel to unhook it from the retaining tabs on the side panels. Remove the front panel, and set it out of your way. 4. Use a Phillips-head screwdriver to remove the four outside perimeter screws that secure the shroud and tumbler front to the dryer cabinet. Pull the shroud and tumbler front away from the tumbler while lifting the top panel partially up. 5. Reach both of your hands underneath each side of the tumbler. Use your left hand to grasp the idler pulley, and pull it to the left while using your right hand to slip the belt off the motor pulley. Pulling the idler pulley to the left releases tension on the belt. You can now slip the belt off the back of the tumbler. 6. Take the old belt with you along with the model number of your dryer to purchase a new belt. Most appliance repair shops will have replacement belts in stock. Make sure that the new belt matches the old one by comparing the two. 7. Slide the new belt over the rear of the tumbler with the ribbed side pointed to the inside. Using both hands under the tumbler, route the belt around the motor pulley and idler pulley. Pull the idler pulley to the left while routing the belt, and carefully allow the idler pulley back to the right to apply tension. 8. Reattach the tumbler front and shroud to the front of the cabinet using the retaining screws. Place the front panel over the side retaining tabs, and push it down to lock it in place. 9. Open the dryer door, and secure the front panel to the shroud using the retaining screws. Close the dryer door, and plug the power cord back into the dryer electrical outlet.
first check and make sure the power breaker is on. next the door when it closes there is a safety switch normaly there is a small hole around the frame of the door. when you push on it, you shoud hear a clicking noise. if you don"t, that switch will prevent the tumbler from turning another thing is the belt that goes around the tumbler if it's loose or broken the tumbler will not turn. that can be checked by accessing the bottom panel in the back the belt should be tight. good luck!
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
take the door off. take the front panel off. take the belt off the tumbler. take the tumbler out. you should see the roller. everything is held with regular phillips head screws.
Thanks
