20 Most Recent Maytag MDE9700AYM Electric Dryer Questions & Answers
2answers
Dryer will not start when I push the start
The buzzing is a good sign that the motor is bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
3/1/2015 3:01:33 AM • Maytag... • Answered on Mar 01, 2015
Dryer runs and drys but makes a thump soud every revolution "like a tennis ball"
Check the belt that is on the drum. It sounds like it may have a chunk broken off of it and you may need to replace it.
8/9/2014 3:12:04 PM • Maytag... • Answered on Aug 09, 2014
Does the top come off the maytag electric dryer mde9700sym
unscrew the screws on the back and it'll slide off when pulled
3/5/2014 8:50:04 PM • Maytag... • Answered on Mar 05, 2014
0answers
My neptune MDE9700AYW heat comes on for about min and half then goes out I have check all thermostats all four. I have been told it my be in the main panel
Have you cleaned the sensor strips with windex? They may have a coating of wax on them from dryer sheets and such. If no moisture is detected the brains of the thing shut it down. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1/9/2013 6:09:27 PM • Maytag... • Answered on Jan 09, 2013
I have a maytag neptune dryer model mde9700aym. my problem is this we moved into a new home and when i plugged the dryer into the socket it did not sound like it should (it was very noisy), so i unplu
Its not level and the dryer blower is hitting. There are adjustable screws at each corner try rotating them out until you feel no wobbling or it doesn't shake. Also if you put to heavy of a load in it, it will also make that noise.
12/27/2011 3:05:02 AM • Maytag... • Answered on Dec 27, 2011
2answers
Will not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./,./';
8/13/2011 12:28:38 AM • Maytag... • Answered on Aug 13, 2011
The dryer will not start. When I press start
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
8/11/2011 11:41:47 PM • Maytag... • Answered on Aug 11, 2011
2answers
4 prone receptical in house,4 prone wire,3wire
As for the red and black of new cord connect on red and black on terminal block on back of dryer for the white it will have a brass link that connects from the white terminal on block to the dryer cabinet.remove that brass link attach the green wire to where the brass link attached to the cabinet and the white onto the terminal block
7/28/2011 10:15:55 PM • Maytag... • Answered on Jul 28, 2011
Dryer has power. controls light
Label each of the two (sometimes there are three) wires leading to the start switch so that you will be able to correctly reattach them later. Using caution, remove the wires. They are connected with the use of metal slip-on connectors. Grasp the connectors and pull firmly from the connectors. Do not pull on the wires themselves. You may need to use a pair of needle nose pliers to help you.
Use your ohmmeter to test your switch for continuity. Begin by setting your ohmmeter to measure resistance at a scale of R x 1. If yours is a two-wire switch, touch one tester probe to each of the switch's terminals. You should receive a reading of infinity. While the probes are still touching the switch's terminals, press in on and hold the switch. The reading should change to zero.
if it doesn't test like this, replace the switch
7/12/2011 8:39:47 PM • Maytag... • Answered on Jul 12, 2011
Dryer will not heat at all set in any selection
heatman101;';
6/30/2011 3:36:59 AM • Maytag... • Answered on Jun 30, 2011
Dryer flyte srews are loose need to remove top to
hello, There are two screws on the rear of the top cover. You remove the two screws and push back on the top and then lift it up. Hope this helps..
6/6/2011 3:44:59 PM • Maytag... • Answered on Jun 06, 2011
My dryer does not get hot. We checked the lint
check this blog by heatman http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won Please rate my response
5/28/2011 1:33:13 AM • Maytag... • Answered on May 28, 2011
Maytag MDE9700AYM Electric Dryer Logo
67 questions posted
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
View Most Popular
Maytag Dryers
  • Maytag Dryers
Most Popular Question
maytag mde
  • Dryers
