Model 665.1378 the door becomes unlatched after it has started and you need to hold it for a while till the cycle restarts and then it usually holds.
Please check this link: door lock
SOURCE: Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console. It is a small silver colored device
attached to a white plactic bracket. In some model dishwashers the
wrong gage wiring was used causing the wires to heat up and trip the
thermal fuse. There was no apparent risk of fire or anything like that,
but the thermal fuses didn't tolerate the heat differential too well. A
fix for the problem was to purchase a thermal fuse replacement kit
(found at most appliance repair stores) that had thicker wires. The
part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at
repairclinic.com. Order on line and have the part shipped directly to
you. Now...to access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even
though the dishwasher is not running, the control board still has live
voltages present.
2. Open dishwasher door and remove the top screws that hold the console
in place. You shouldn't have to remove the lower screws unless you plan
on removing the entire door panel.
3. The control panel should pull off from the front enough to where you
can access the control board. There is a thermal fuse mounted on the
board with two wire leads going to it. The fuse is silver in color and
mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it.
Leave plenty of wire to accommodate. There will be instructions included
with your replacement kit. Ensure you follow the direction thoroughly
and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging
the old fuse and replacing it with the new one (been there). The fuse
will eventually blow again. Follow the instructions provided and you
can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop and they SHOULD have the part available. This is a known problem and a common fail item.
SOURCE: Kenmore Elite Dishwasher clean light ind flashing and won't start
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
SOURCE: kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
