You cannot attach any extra aerial to the Belkin router, even if you attach it will not help you to increase the wireless signal strength. Its of no use in adding extra serial.
I'm afraid you can't boost the sgnal from the router without buying a repeater/booster box.
You will get the best wireless performance from your router if it is in the highest position possible in the house - of course it may be impractical to move it but, if you can, then do so.
The only other option is to purchase a booster. I don't know what country you are living in, so I can't give definitive advice. You should try a search on google or ebay for "wireless router booster"
Everything is possible!
If you want more advice please reply here with a comment and I will try to provide further assistance.
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible move the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) . 4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Unfortunately the range on a G router is usually reliable to about 200 ft or so, depending on obstructions. There is no way to boost the 802.11g signal. You'd be looking at upgrading your router and card to 802.11n, which would give you increased range. .
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
