HP Officejet 5610 All-In-One InkJet Printer Logo
Posted on Nov 30, 2008
Dismantle and remove battery officejet 5610
Howto dismantle printer officejet 5610,and remove battery
Joe Fine
Level 1:
  • Contributor 628 Answers
  • Posted on Dec 01, 2008
Joe Fine
Contributor
Level 1:
Answers
628
Questions
Helped
149127
Points
66
It would be extremely difficult to disassemble the printer, and the battery is usually not replaceable. Why did you want to replace it anyway? It should last the life of the printer.
I am receiving "cartridge error" message on my 5610 printer.if anyone knows a way and a solution to reset the memory of cartridge or printer to solve this error?
Did you try to completely unplug it form electricity for at least 15-30 minutes? Hard reset might help you with this error. Also, download the user's manual and search for possible solutions Hp Officejet 5610 Manual
2answers
How to uninstall officejet 5500
all should be handled trough printers and faxes in xp or similar if u have vista. there is just remove option if u right click it
HP 5610-CARTRIGE ERROR/USING SAME PAPER/REMOVED AND RE INST'D. INK CART./ STILL ERROR
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf18
2answers
Please help me
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab95
Epson C86 print head/cartridge head won't move.
Hi Beverley
There is some confusion here. You say "ink sponge needs replacing" in an Epson C86 (although you have your query posted under HP Officejet 5610!) - I presume you mean the waste ink pads. If so, you need to dismantle the printer - the pads are not under the print head but deep inside the case. I can provide all the information you need to complete this task if you really want to do it yourself. Please post a new comment requesting this assistance if you do.
Howto dismantle officejet printer 5610, and remove battery
well if you are having a paper feed problem then you dont need to disassemble the printer. observe the area where you feed the paper in and you will see two rollers pressing don on th paper when loaded. theas two are spring loaded to adjust to the thickness of the paper in the tray. 10 sheets or tyenty five . it still appplies downward pressure on the whole stack of paper. The rubber roller is on the right ,and a hard plastic one on the left. the rubber roller is the motorized feed roller. Clean both with a q-tip.
3answers
k24674
Grand Canyon Tech
Grand Canyon Tech
