Canon FAX-B820 Plain Paper Bubblejet Logo
Eugene Melfi Posted on Jan 11, 2007
Incoming telephone calls
Dialing out either to fax or telephone is no problem. Receiving a fax is fine....but receiving telephone calls on this machine is problematic. When dialing in from an outside line, you hear the normal call tone on the line, then a moments silence (like you're being transferred) and then a different dial tone (more like an old style internal call tone or the tone you hear when calling abroad). Meanwhile, the fax machine itself does not make any noise at all until the second call tone begins. If the caller hangs up at this point (as they often do due to the odd dial tone) the machine continues to ring until I answer it...when theres no caller on the line anymore.Finally, I cannot use BT's 1571 function at all with this machine. I have tried plugging a different phone into the same socket and this went well, no problems at all, 1571 worked ok and dialing in to the line gives a normal call tone and the phone rings at the same time (as you would expect). I have read the manual and checked the 'Receive Mode' function and all of the settings are as they should be....I have asked Canon but they are bemused too! Any help greatly appreciated. Thanks.
  • Anonymous Mar 26, 2014
    Can call out but can receive calls but can't hear a ring tone when phone rings
Anonymous
Level 1:
  • Contributor 59 Answers
  • Posted on Aug 10, 2007
Anonymous
Contributor
Level 1:
Answers
59
Questions
0
Helped
23904
Points
64
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
How do I receive a fax?
If the machine is located away from the telephone, pick up the handset and dial 25 (the remote receiving ID) to receive faxes (remote reception).
bullet_s.gif If you use a rotary pulse line, temporarily switch your telephone to tone dialing. For details on how to switch to tone dialing, see the instruction manual supplied with your telephone.
bullet_s.gif If you have an answering machine connected to the machine that can carry out remote control operations, the security code for this function may be the same as the remote receiving ID. In this case, change the remote reception ID in REMOTE RX ID in REMOTE RX in RX SETTINGS under FAX SETTINGS.
Lots of useless reports printed
You should get the Number of the Companies Fax Number and complain to your Telephone Provider, that your constantly receiving fax messages from a Company that's obviously dialing the wrong number.
The fact that they're not getting any replies from you surely should lead them to realize that they are dialing a wrong number.
Then perhaps the Telecoms Company can put a Block on the Number from calling you again.
Worth a Try :-).
4helpful
2answers
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Not receiving any faxes but sending
Note: check your equipment for:
Fax machine must be connected to an answer machine
Receiving a fax automatically:
1 Make sure the Fax Auto Answer light is on.
2 To set the number of telephone rings before the printer automatically receives faxes,
2 Set the answering machine to answer incoming calls before the printer does.
after five rings.
3 To set the number of telephone rings before the printer automatically receives faxes.
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
old marine
old marine
ZJ Limited
ZJ Limited
