Panasonic Toughbook 71 Notebook Logo
Anonymous Posted on Nov 27, 2008
Cant run Toughbook on Xp for some reason
I am trying to run my Toughbook CF-71 off a XP disc but it says a file cant be loaded and the error code is 7. can someone help me?
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Nov 28, 2008
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
28869
Points
148
It could be your HDD or DVD drive problem.
Try low level format your HDD and re-install XP again.
If it still problem come again then try clean the laser unit of the DVD drive or replaced another one if you can.
Instal xp on panasoc cf 71
had same problem with loading win xp proff on cf 74 toughbook mk1.
soution for me was downloading sata hdd controller from panasonic toughbook support site, loading the driver onto floppy drive, using usb floppy with driver ready to use, loading win xp profesional and on first loading win screen pressing f6 when prompted at beginning of win intallation, when on screen instructions to load sata driver appeared, i followed on screen instructions and loaded 3rd option from floppy sata drive mobile driver, left usb installed untill xp loaded and running, do not remove usb floppy untill win loaded, i really hope this helps you
1helpful
2answers
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Toughbook CF-73J cant find drivers!!!
It does't matter. There is no special drivers for SP2. good luck.
1helpful
2answers
the windows xp sp1a drivers should work fine on the sp2 after you get the network card working try windows updated to see if it list any new updated drivers
https://eww.pavc.panasonic.co.jp/pc/itn/drivers/d_menu_en.html#CF-73
XP Booting off CD trouble
may be the file is damaged, if this is the only pc original cd, try to repaire it using the "disk repair polish" can be found in the markets.
How do i change boot sequence
When the BIOS starts and the company logo comes on, there is a bunch of words written at the bottom of the screen.
See for one which is something like "change boot order". Press that corresponding button on the keyboard. Now follow the things on the screen and explore.
You cannot use the mouse in this 'DOS'sy looking screen. Use the arrow keys on the keyboard to navigate.
5answers
Install XP on Panasonic Toughbook CF-27 ?
Your cd/dvd drive doesn't have to be bootable to install Windows XP. Did you encounter a problem?
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
