Scanning various documents results in very dark images and/or dark blue lines through the images
SOURCE: Lexmark Imaging Studio
The Downloaded software may not have the Lexmark Imaging Studio on the downloaded drivers.... In this case u have to scna and Preview the scanned images using Windows Photo Gallery..... Click on File and Click on Import from scanner or Camera........... Then again click on Import...........It will scan and preview the Applications to u.... Thanku.......
SOURCE: Lexmark x4550 wireless scanner pin code
The Pin code, if it's the 4 digit pin - is one you can create yourself to be used when scanning as a login, but is not necessary, it can be left blank, unless one was already entered upon installation. The manual can also be downloaded from the Lexmark site, type in your model # (ei: x4550) in the search box on the lexmark site, then technical support & then publications, you should find the "getting started" & "user manual".
SOURCE: scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Please download and install the scan driver from support.lexmark.com. After installing the scan driver, please check the scanner under Imaging Device from device manager. If scanner shows under imaging devices, open the scanning program and scan a document.
For further assistance, please contact Lexmark Technical Support.
On scanning the results are very dark, with blue strips through the text. photographs come out almost completely black. the intensity of the scanning light is very low more toward a yellowish color instead of being a bright white. Is it possible to replace the scanner light bulb in this printer?
