I have a maytag mfi2266aeu stainless steel bottom freezer door refrigerator that the handle has been broken off. how do i repair it
SOURCE: Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
SOURCE: stainless steel refrigerator with a bad scratch
Check out this site and see if it helps. Usually stainless has to be buffed out. http://www.stretcher.com/stories/01/010723a.cfm
SOURCE: freezer door handle loose
Can you give me the model number? Ther are alot of variation of handles.
SOURCE: not getting ice
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
SOURCE: Maytag MFI2568AES Stainless Steel Bottom
i have the handle it was broke off at each end where screws were broke off,i need to know how to take apart the door so i can buy new screws to reattach handle
