20 Most Recent
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Questions & Answers
My Maytag MF12568AES Refrigerator is not cooling
This happens to my Maytag like clockwork every summer. The freezer works fine but the refrigerator stops cooling. The first time this happened, it was the fault of the small plastic DC fan that sends cooling from the freezer compartment to the refrigerator section. A technician replaced the DC plastic with an AC metal fan he guaranteed would last the life of the refrigerator. He blamed govt energy standards as the reason Maytag uses the cheap DC plastic fan in the first place. Problem solved. One year later, same issue with no cooling in the refrigerator, freezer fine. Again today, nearly one year to the day! SOLUTION? Trip the circuit breaker or unplug the refrigerator for a minimum of 5 minutes. A reboot now fixes the problem every time. Who would have thought you'd ever have to REBOOT your refrigerator?
4/24/2023 3:28:04 AM •
Maytag...
Answered
on Apr 24, 2023
Door Handle - Screw coming out
Not quite sure about your problem but, if it is a wood screw going into your door, you can take the screw out a insert a hardwood toothpick into the screw hole and reinstall the screw. this will fill any stripped out of the hole and screw should fit securely. If it is a metal to metal problem you can go to the hardware store or even walmart and buy a product called " Locktight". it is a liquid that you put on the screw and reinstall it. it will dry and lock the screw in place. Buy the blue if you want to eventually take it out at some point or buy the red, if you want it to stay in place and take a lot of effort to get it back out.
1/12/2023 1:14:50 AM •
Maytag...
Answered
on Jan 12, 2023
How do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET. THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
9/7/2022 1:58:32 AM •
Maytag...
Answered
on Sep 07, 2022
What is the role of stainless steel products?
Products which are manufactured by stainless steel is mainly depend up on the type and quality of stainless steel means it may be plain, ordinary stainless, like in a handle or pot, then any alloy steel drill will do. On the other hand, if it is hardened stainless like what is used in instruments, you probably will need carbide, although you might get a tool steel drill to make one hole.
Stainless steel is defined as a steel alloy with a minimum of 11.5 wt% chromium content. Stainless steel does not stain, corrode or rust as easily as ordinary steel, but it is not stain-proof. It is also called corrosion resistant steel when the alloy type and grade are not detailed, particularly in the aviation industry. There are different grades and surface finishes of stainless steel to suit the environment to which the material will be subjected in its lifetime. Common uses of stainless steel are cutlery and watch straps.
For detailed information visit at:
Solutions of Stainless Steel Products
7/13/2022 7:22:30 AM •
Maytag...
Answered
on Jul 13, 2022
Replaced circuit board, refrigerator wont allow programming, just says PE0 000
Dear joe, I had the same problem when my refrigerator was broken. You need to re-program the control panel as follows: 1. First you need the Program Code for your fridge. It is on the plate on the inside of your fridge, on the same plate that has your Model # and Serial # on it. 2. Programming is done with the refrigerator doors open. 3. Press and hold the Door Alarm keypad on the control panel. 4. Then press and hold the Freezer Temperature Down keypad. 5. Then release the Door Alarm keypad and wait 3 seconds. 6. The control pad will then display PE to indicate it's in programming mode. 7. Entry is confirmed by pressing the Freezer Temperature down keypad once more. 8. The control panel will display the current program code. It should be the same one that I asked you to find in Step 1. 9. If the program code is the correct one, exit the programming mode by closing the refrigerator doors. 10. If the program code is not the correct one for your refrigerator, press the Refrigerator Temperature Up or Down to change the value with each keypress. 11. The decimal point indicates the selected digit. Press the Freezer Temperature Up or Down to select the next digit. 12. Once the desired program code is displayed, press and hold the Freezer Temperature down keypad until the program code begins flashing, indicating that it's been saved. 13. Again, when you're done, exiting the program mode is done by closing the refrigerator doors. Hope this helps alot of people out there. I'm not sure what the problem is at Maytag, but they're extremely slow in getting parts shipped for their units. The local Maytag repair people have indicated to me that they are seeing an overwhelming number of Maytag refrigerators needing repairs that are around the one year age range. They say the quality of the new units is terrible.
3/2/2022 5:18:13 PM •
Maytag...
Answered
on Mar 02, 2022
Hv board needs to be replaced
Try www.searpartsdirect.com
Or
Give me your city and state I'll find you a local appliance parts supplier.
8/7/2019 6:07:41 PM •
Maytag...
Answered
on Aug 07, 2019
Maytag mfi2568aes control panel
If the refrigerator water dispenser is not working the water supply tube in the door may be frozen. This will be difficult to track down. Look for a connection point at the bottom or top of the door, try removing the hose and blowing air through it and out the dispenser. Next it could be the water valve that sometimes has twin valves for ice and water combined, third is low pressure into the line (bad main valve) or clogged filter... you need about 20psi for function. Last is the door switch, when the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice and water dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn't have continuity it should be replaced.
8/7/2019 6:00:53 PM •
Maytag...
Answered
on Aug 07, 2019
Control panel on my fridge
Pull the power cord for 5 minute to reset the control board. if this control panel malfunction still exist after the reset, replace the control circuit board.
This is a typical control fault that should be corrected by pulling power for 5 minutes. if not, this reset will confirm major damaged to the circuit board.
1/14/2017 4:26:09 AM •
Maytag...
Answered
on Jan 14, 2017
Which is the best mainly stainless steel manufacturing company?
Huge number of stainless steel manufacturing companies are available around the world, so only it's difficult to say that which one is the best in all respect like quality of stainless steel, number of products manufactured and many more.
As the products manufactured by stainless steel is mainly depend up on the type and quality of stainless steel means it may be plain, ordinary stainless, like in a handle or pot, then any alloy steel drill will do.
So mainly good stainless steel manufacturing company provides their customers, unique range of stainless steel products manufactured using the latest technology. All their products are of the best quality which meet the international standards. Integrity and customer satisfaction should be their topmost priority. I think that I know a company who is focusing on the above parameters, called
Complete Solutions of Stainless Steel Products in India
4/28/2016 11:50:51 AM •
Maytag...
Answered
on Apr 28, 2016
