I insert memory card and camera says no memory card
When this memory card error occurs on the G9, it is most often from a faulty card reader in the camera. If you need help with it, try this place: www.camerasandparts.com They just specialize in the Canon Powershots and they know these models so well. Go to their site and send them an email, I'm sure they can tell you what's going on with it. Hope they can help you with the problem, good luck.
SOURCE: getting memory card error
Some cameras require a new Firmware update of it's internal brain so it can recognize larger capacity memory cards. Check out your cameras website, look up the FAQ column or support and see which memory card sizes are compatible.... Good luck
SOURCE: Loaded new memory card, and screen reads memory
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
SOURCE: PowerShot S410 problem. Camera powers on and lens
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see this link.
SOURCE: Memory card error
Having gone over a month with no response, I assume it was just a matter of SD versus SDHC cards.
SOURCE: I have a new Canon
Insert the card into a card reader and format it on the computer. See if that works. Format using FAT32 as its more reliable than the FAT it uses by default. If the camera supports FAT32 you can expect it to last atleast a year before you need to format it again
