It is a new chain saw just about 2hrs runing time i try to get a better performance by playing with L and H adjustment screw and the idle screw and i lost the initial setting i should lefted has she was at list she was working before. Now i need to know the initial setting for the L and H and the idle adjustement scew
SOURCE: I need a manual for my Poulan gas chain saw. It
Manufacturer's site here:
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: need chain saw fix
I would try Poulanpro.com and look at their user manuals for the adjustment. They are different on most saws. Hope this helps
SOURCE: I just purchased a new model P3314 Poulan chain
PDF manual for the P3314 Chainsaw can be downloaded here
SOURCE: poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
SOURCE: Poulan P3314 Automatic Oiler
Go to Poulanpro.com and look at a parts explosion and they also have a toll free number that might help. let me know if not and I will research more.
