Add toner error
SOURCE: SYSTEM ERROR
The Kyocera MK 3050 shows system error. We have turned it off and back on this does not help.
SOURCE: c-6000 error
c-6000 is a fixing film error you can reset this throught he maintence mode if you will give me the exact model on the macine i can tellyou how to reset it
SOURCE: Kyocera Mita 2050 there are streaks
If you send a print job or print a report from the copier and there is no streaks then the problem is most likely the thin **** glass to the left of the large glass. It just needs to be claened.
If the streaks are happening when printing and copying then the problem is most likely your drum unit (MK-410) or possibly the fixing unit (FU-410), the fixing unit is the one that gets hot.
As the drum gets old it can cause print/copy issues and the cleaning blade that cleans the drum gets to the point it doesn't clean the drum properly causing streaks.
The heat roller has a teflon coating on it and as the roller gets older the teflon starts to come off and can effect prints/copies.
The drum unit should be replaced every 150,000 pages and the fixing unit every 300,000 pages on the KM-2050.
I hope this is helpful,
Shawn
