What drivers do you want to download?
There are not drivers for Linksys router. It works on a software called as firmware?
How many wireless computers do you have?
What is the operating system on your laptop?
If your wireless network is secured then make sure that you have the correct network key.
See How to setup Linksys router
See how to connect to the wireless network
SOURCE: i lost my start up **** for my linksys wrt54g2 v1
You can download it from here,
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G2
Select XP, Vista Setup wizard download.
Don't forget to give me a good rating as well as your vote.
SOURCE: i need installation software for a linksys WRT54G2
go here and select yours then CHEERS!
http://www.linksysbycisco.com/UK/en/support/WRT54G2/download
yours is version 1 not 1.5
SOURCE: i lost my linksys wrt54g2 v1 cd i need to install
http://www-ph.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=PH%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740141396B01
SOURCE: I need a free download driver for wrt54g2 v1
Hi and thank you for using fixya
Check the link below, just select your router hardware version that can be found at the bottom of the router. After you do that you will be able to download free driver
thanks good luck
http://www.linksysbycisco.com/US/en/support/WRT54G2/download
SOURCE: l have lost internet connection with linksys
Stop using the setup disk. It does not work. Connect to your router via a web browser to 192.168.1.1. Username blank, input your password and configure the router as normal.
i can't connect my PC & Laptop to my router linksys......
