20 Most Recent Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Questions & Answers
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
Linksys WRT54GX2... | Answered on Oct 22, 2019
Hold the reset key down with power on for 15 seconds.
In addition, there's an error in some copies of the user manual, the correct login is:
username: admin
password: admin
hope this helps if can help further let me know
Linksys WRT54GX2... | Answered on Oct 09, 2018
The Linksys adapter should have a program you open to find and connect to your router. If not, you can use the Windows Network settings to find your router and connect. Although 54G is a slower speed, they should still connect.
Linksys WRT54GX2... | Answered on Jan 28, 2018
Linksys Wireless-G WRT54G Router istallation
Linksys WRT54GX2... | Answered on Jun 30, 2016
Please login to router page by 192.168.1.1 enter user name = blank and password = admin
Once you click on the wireless tab>wireless security
Under this you can check the wireless key.
please follow the link.
Wireless Security
Linksys WRT54GX2... | Answered on Jun 19, 2014
Yes or a laptop to initially access the setup page of the router.
Open the router setup page with address 192.168.1.1
Username =nothing leave this blank and password is
ADMIN and then go to
the wireless security settings.
Select WEP or WPA
enter the password and save the settings.
Reboot the router after that and now your wireless signal is password protected
Wireless Security
http://www.dd-wrt.com/wiki/index.php/Linksys_WRT54G2
Has everything you need.
If you have a specific problem let us know the details.
Linksys WRT54GX2... | Answered on Apr 24, 2014
Are you looking for wireless network password or the router password.
The default linksys router password is admn.
If you are looking for the wireless network password then you will need to access the setup page of the router.
See How to find wireless network key.
See Video: How to find wireless network key.
Linksys WRT54GX2... | Answered on Apr 02, 2012
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Linksys WRT54GX2... | Answered on Dec 09, 2011
Resetting the Linksys Router to Factory Default
To reset the router to its default settings, press and hold the Reset button located at the back of the router for 10 seconds.
IMPORTANT: Older Linksys devices may require pressing and holding the Reset button for 30 seconds to complete the reset process.
kb19584-003_en.png To perform hard reset on your Linksys router, follow the steps below:
NOTE: The location of the Reset button may vary for every model.
If the normal reset does not work, unplug and re-plug the router's power adapter while pressing the Reset button.
You can also reset the router via its web-based setup page. Follow the steps below to learn how.
Resetting the Router Using the Web-Based Setup Page
Step 1:
Access the router's web-based setup page. To learn how, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click the Administration tab then click on the Factory Defaults sub-tab.
kb19584-004_en.png NOTE: If the screen on your router's web-based setup page is different, click here.
Step 3:
Under the Factory Defaults section, click on the Restore Factory Defaults button.
kb19584-005_en.png The default settings of your router are now restored.
Linksys WRT54GX2... | Answered on Sep 21, 2011
yes its fixable, you can program back the wireless modem, by holding down to the power button and the restart after ok
Linksys WRT54GX2... | Answered on Sep 18, 2011
Try to reset with a 'Power Reset':
1. Pull the power from the router for 30-60 seconds and reconnect the power.
2. Check again.
If this does not help, the (1) powersupply or the (2) router may be faulty.
Linksys WRT54GX2... | Answered on Aug 30, 2011
Hello nanpw,
To reset your router to factory, take a paper clip and press the reset button. Hold it for about 30 seconds or until the lights on the router flash. open a web browser and type 192.168.1.1 username is (blank) password is admin then run the wireless setup utility, after your laptop is connected its always a good idea to include security.
Linksys WRT54GX2... | Answered on Aug 15, 2011
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
221 questions posted
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
WRT Linksys
  • WRT Linksys
Most Popular Question
linksys wrt54gx2
  • Computers & Internet
