20 Most Recent Linksys WRT54GL Wireless-G 54Mbps Broadband Router w/Linux all-in-one Internet-sharing Router With 4... (WRT54GV4) Questions & Answers
HOW TO SET A PASSWORD IN THE ROUTER?
There are 2 credential accounts. One for the router via web interface. It is useless to set one up, since the reset is located in the back. The second is for the wireless normally known as the SSID for the user and the Paraphrase / Key for the password. Log in via web admin. 192.168.1.1 admin is the default password with no user. Reset in the back if you need to clear any and ALL custom setting by holding it till it cycles.
11/28/2012 8:57:16 AM • Linksys WRT54GL... • Answered on Nov 28, 2012
Router connects one computer but not another
It might be restricted by MAC address you might have to log in to the Router
8/18/2012 6:34:12 PM • Linksys WRT54GL... • Answered on Aug 18, 2012
The connection cannot detect the wireless
Your computer/laptop needs the encryption key that is in the router's wireless settings before it can connect to the wireless router..
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Apply these settings to the wireless card in your laptop/computer.
Connect your DSL or cable modem to the D-Link router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
1/1/2012 3:53:22 PM • Linksys WRT54GL... • Answered on Jan 01, 2012
2answers
The network is working but
If the internet is not working first thing to check here is the internet connection from your modem without the router, make sure that your computer can access the internet when computer is connected directly to modem, if no internet without the router you need to contact your ISP for that, but if there's internet without the router you need to reset and reconfigure the router.....if you have the setup CD of the router just run that to reconfigure it back.........
12/15/2011 2:13:28 PM • Linksys WRT54GL... • Answered on Dec 15, 2011
Unable to get to the Linksys page for a 54Mbps
Are you trying to get into the router settings?
Type in 192.168.1.1 in the browser and the username/password box should come up.
Hope this helps!
Don't forget to rate:)
12/26/2010 4:18:45 PM • Linksys WRT54GL... • Answered on Dec 26, 2010
When I route my cable line through router I cnnot
sounds like you recently upgraded your Pc or software, maybe even just a driver update? If so it will help figure out your problem.
Always try to reboot your network(router,modem,pc,laptop)for at least 30 sec, usually its a communication error or a firewall issue that blocks router access, and then again it could be a driver or software compatibility problem. email me with more info if you still need help [email protected]
12/15/2010 1:41:03 AM • Linksys WRT54GL... • Answered on Dec 15, 2010
2answers
Installation broadband router linksys WRT54G v5
In your internet explorer address bar, type in the ip address of 192.168.1.1 and see if it asks you for a password.
If that isn't it, try 192.168.1.245.
The default password is admin. No username.
Also, go to www.linksys.com and they have free chat support and can walk you through this issue.
12/14/2010 5:01:11 AM • Linksys WRT54GL... • Answered on Dec 14, 2010
Would like to secure my network
Follow this link to download the manual that will give you set by set instructions on your router. And security setup.
http://downloads.linksysbycisco.com/downloads/WRT54GL-EU_11_UG_A-WEB.pdf
10/4/2010 7:53:52 AM • Linksys WRT54GL... • Answered on Oct 04, 2010
Http://192.168.1.253/
If you want to reset to factory settings, there should be a small, pin-size hole on the back somewhere you can press with a toothpick --- hold it in for 15 - 20 seconds and you should be good as new
11/16/2009 1:11:35 AM • Linksys WRT54GL... • Answered on Nov 16, 2009
I have a Linksys WRT54GL wireless-G router
Please
  1. Verify File and Print Sharing is installed for the wireless network card on each computer.
  2. Try pinging each computer.
  3. Try doing Start, Run, and in the browse line type \\and the ip address other computer. For example, if computer B has the ip address of 192.168.1.3 from computer A, do Start, Run and type in \\192.168.1.3 to see what that brings up.
Please post back if you have any questions.
9/15/2009 3:32:45 PM • Linksys WRT54GL... • Answered on Sep 15, 2009
The default username and password to configure router doesnt work
Try to turn off your modem first before trying to open the router's setup page. By default, there's no username and the password is admin. Also turn off any firewall you have.
4/1/2009 4:30:46 PM • Linksys WRT54GL... • Answered on Apr 01, 2009
Wireless set-up
Did you try to check if the cord is properly connected to the router? Check if you can connect to another LAN port. If the router is working on the another computer it means that there is something on part of your computer that is not working properly, Check also the Ethernet cable if working properly? or try to use another Ethernet cable to connect with the computer.
3/18/2009 12:08:39 AM • Linksys WRT54GL... • Answered on Mar 18, 2009
Registering
what are you trying to register? I've never registered my router? Do you mean you just bought it and you want to register it with the company? try their website or see if you got a registeration form in your documents that came with it.
3/17/2009 10:58:58 PM • Linksys WRT54GL... • Answered on Mar 17, 2009
Router doesn't broadcast?
Make sure the brodcast light is on. and that brodcast is on in the congfig screen of the router.
3/15/2009 8:42:39 PM • Linksys WRT54GL... • Answered on Mar 15, 2009
Cannot complete setup
Did you set new admin password in your setup? If not, just type user: admin and 'blank' password (do not fill the password. If yes, and you can't log in using your new admin password, try to reset your router with push reset button (small black button in the back side of router). Follow the reset procedure that found in the manual.
P.S.: If this information was helpful, please rate this solution.
3/12/2009 10:34:33 AM • Linksys WRT54GL... • Answered on Mar 12, 2009
3answers
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
2/1/2009 7:41:33 PM • Linksys WRT54GL... • Answered on Feb 01, 2009
I am visiting my dad
calle linksyst and then the neighbor and got it done thanks
1/8/2009 3:22:03 AM • Linksys WRT54GL... • Answered on Jan 08, 2009
Connection
You have to set the wireless connection
Check if you have the wireless card ON or check if your wireless card is installed
My computer >> right click >>Properties>>Hardware>>Device Manager>>Network
If yes,
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
11/20/2008 9:37:41 AM • Linksys WRT54GL... • Answered on Nov 20, 2008
Help me!!!!!!!!!!!!!
Do you have the software C-D for your router? If not go to Linksys.com and chose your model and d/l right from the website. There you can get the latest firmware. Then follow the instructions (it should have pictures to go with) then you should be up and running within about 25 minutes.
9/16/2008 4:38:57 AM • Linksys WRT54GL... • Answered on Sep 16, 2008
2answers
Linksys routerr
Try to do a complete power cycle on your devices. Turn off router, turn off modem, turn off computer. Wait for 30 seconds then turn on modem first, wait for all the lights to stop blinking then turn on router the reboot computer. Hope that helps
8/6/2008 11:13:30 PM • Linksys WRT54GL... • Answered on Aug 06, 2008
Computers & Internet Logo
33 questions posted
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
WRT Linksys
  • WRT Linksys
Most Popular Question
http 192 168 1 253
  • Computers & Internet
