Bought new Acer Inspire with windows 7. Found driver for my HP dj3820 no longer available, but told I could use 970cse. Have installed driver but printer will not print - just gives 'error' in printer icon.... any ideas?
SOURCE: Have Windows 7 on my laptop. Have a HP Deskjet
simply download the new drivers from HP and install them , that will fix your problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: HP Deskjet 3820
Tray this link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=75045&cc=us&lc=en&dlc=en&product=75045&dlc=en&lang=en
cheers
SOURCE: HP 6940 Deskjet driver not installing WINDOWS 7
hi,the reason why it most probaly comes with that error is that the driver is not meant for windows 7,so go on line check hp site, printer drivers and download.
SOURCE: Will HP Deskjet 722c work with Windows 7? There
If you are using a 32
bit version of Windows 7 you can add a driver using the following: go
to the Devices and Printers folder, Add a printer, Local printer,
LPT1: (or which ever parallel port the printer is connected to),
select the Deskjet 720c driver. You may need to click on the Windows
Update button if the driver does not show up initially in the list.
If you are using a 64 bit version of Windows 7 there is not a solution at this point, the supplied drivers have an issue.
SOURCE: Have HP Deskjet 940c on Windows 7. Only drivers
Find another computer (laptop?) that is running Windows XP or Vista. Install the HP device-drivers.
Connect the printer to that other computer, and use the software to display the ink-levels.
