3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
also blower works, seperate plug in. the lights come on around the control knobs but no heat from the heating elements.
