20 Most Recent
Bosch NET5054UC 31 in Electric Cooktop Questions & Answers
Bosch oven display does not work at all but the cooktop works. what is the problem?
There could be a few different reasons why the display on your Bosch oven is not working, but the cooktop is functioning properly. Some possible causes include:
- A problem with the control panel: The control panel is responsible for controlling the oven and displaying information on the screen. If there is a problem with the control panel, it may be preventing the display from functioning properly.
- An issue with the oven's electrical system: If there is a problem with the oven's electrical system, it could be causing the display to malfunction. This could be due to a problem with the wiring, a faulty component, or a power issue.
- A problem with the display itself: It is also possible that there is a problem with the display itself, such as a damaged screen or a malfunctioning component.
In order to determine the cause of the problem and fix it, you will likely need to have the oven inspected by a professional appliance repair technician. They will be able to diagnose the issue and recommend the appropriate course of action.
F9 code flashing on Bosch induction cook top
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Bosch cooktop Flashing F9
again.
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair.
From the Manufacturer
Igniters on my Bosch gas cooktop not working. I guess it needs cleaning. How do I do it?
You can try to clean the two pins with degreaser and then soap and water using a skrubby sponge for delicate surfaces However, my Bosch cooktop has had problems with the igniters (particularly on two burners) which required the replacement of the control unit. This requires opening the unit completely and replacing the white plastic box and connections to each burner. It is easy enough to do, but it is a bit scary to lift off the glass as there is probably an adhesive which one has to lift the top off of. Another thing you can try is to adjust the two screws that are uderneath the removable cover of the burner. Sometimes just tightening or loosening them a bit can solve the problem
