SOURCE: 91 kx 250 torque values
Engine Top End:
Auto Decompressor Bolt 104 in·lb
Cylinder Head Cover Bolts 87 in·lb
Cylinder Head Bolts: M10 36 S
M6 104 in·lb S
the S in that means the specified pattern ... just like tightening car tire bolts... please note all that it its INCH lbs....
don't know why it says just 36 for the M10 bolts unless they left out inch lbs
Anything else let me know as i've got a manual for the 250 f... actually i've got a few different ones
Robert
Please take a moment to rate this solution as i've taken a few minutes to find the manual thanks
SOURCE: what is the head bolt torque spec for a kawasaki
28 nm buddy make sure you tighten them down evenly like opposite to opposite
SOURCE: i need to know the torque specs for a ttr 125E hea...
In case nobody can't provide specs.All you have to do is apply a gasket maker before you close the head, and if your a right handed try to use your left hand for tightening bolt and do it cris cross,if the 4 bolts were done then use your right hand for final tightening. thats one technick.
SOURCE: what are the torque specs
The torque specs for your cylinder base nuts are 25ft.-lb.and the head flange nuts at 18ft.-lb.tighten them in criss cross pattern,at three different stages,ex.25ft.-lb.start with 8 then15 then 25,18ft.-lb.start with 5 then 10 then 18.good to go.Hope this helps.
SOURCE: torque specs cylinder head studs
Look here for manual:
http://www.repairmanualclub.com/motomanuals/index.php
