HP PSC Photosmart 2355 All-in-One Printer Logo
Linda Hellwinkel Posted on Feb 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power but not printing - HP PSC Photosmart 2355 All-in-One Printer
Anonymous
Level 3:
Guru:
  • Master 731 Answers
  • Posted on Feb 07, 2012
Anonymous
Master
Level 3:
Guru:
Answers
731
Questions
Helped
328726
Points
2071
Hi Linda,
Did you check if the printer is able to scan or does it makes photocopy? if the printer doesn't respond to any input follow below steps.
  • Power Drain:
  1. Turn the printer OFF using the power button.
  2. Disconnect the power and USB cable from the back side of the printer.
  3. Press and hold the Power button for 30 seconds and release the button.
  4. Connect the power cable and try printing.
  5. If the above steps didn't work try below.
  • Partial Reset: Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button. If you still see the issue try next level of reset.
  • Semi Full Reset:- Remove the ink cartridges; Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the button.
Hp 2840 won't stop printing
power off the printer. removed the network cable only. power on until it display ready. now print a config sheet or menu map. if it print without error then connect the network cable and print config sheet again. wait and observed. if it will start printing garbage then KILL the print jobs queued on the printer. after deleting all print jobs power off and power on printer with network cable connected. I hope that will fix the problem. by the way. was there any error display in the panel display like "49.4C02". etc.
I’m happy to assist further over the phone at https://www.6ya.com/expert/gerardo_bdb2f65bdb2cdd4d
10helpful
4answers
Canon MP145 error E27
  1. plug off power cable
  2. press and hold stop/reset button
  3. plug on power cable
  4. press and hold power button(still hold stop/reset buttn)
  5. still hod power button, loose stop/reset button
  6. press stop/reset 2X then loose power button, wait until 0 displayed
  7. press stop/reset 1X
  8. press power button 1X, printer will print 1 time
  9. press stop/reset 2X
  10. press power button 1X,printer will print 1 time
  11. press stop/reset button 3X
  12. press power button 1X ( no print proses)
  13. press stop/reset 4X
  14. press power button longer than before for turn off printer, if print not turn off plug off power cable
  15. turn on printer and error 27 will disappear
i hope this helpfull
thanks for using fixya
1helpful
Can this Tally Print work with any 7,5v power suply?
The TallyCom works with a 7.5 volt power supply, you would need to ensure the correct size connector is used and also the power supply center pin is of the correct voltage.
Also ensure the power supply is able supply the ampage required by the TallyCom
NOTE the TallyCom+ uses a 5 volt power supply do not use a 7.5 Volt power supply if the print server is the + version
Have hp deskjet 6540 printer. yellow light on right side under x keeps blinking not printing. Am I out of ink?
Follow each of these steps until the problem is resolved:
Remove and then reinsert the print cartridge(s) into the printer.
Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
Manually clean the print cartridges and print cartridge cradles:
Open the printer cover and wait until the carriage moves to the center.
Press the Power button to turn off the printer.
Disconnect power cord from the back of the printer.
Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
Lightly moisten a cotton swab with distilled water.
Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
Reinsert the print cartridges.
Close the printer cover.
Connect the power cord to the back of the printer.
Press the Power button to turn on the printer.
Calibrate the print cartridges.
If the light is still flashing, replace the print cartridges.
My Officejet 4315 All-in-One is printing very very slow How do I fix this problem? I have restarted it and unplugged then replugged it and have restarted the computer and it still prints really really...
The very first thing you need to do determine whether the issue is in the Hardware or in the Software for that on the printer .
1. Load plain paper in the tray.
2. Press the Setup button
3. Press 2 to select Print Report
4. Press 4 to select Self-Test Report . The self-test page prints.
Measure the time (in seconds) it takes for the test page to prints.If the test page prints in less than 60 seconds , this is normal print speed and you do not need to troubleshoot.If the test page prints in more than 60 seconds , go to the next step.
Important ;
Some products print faster than others. If the test page exceeds 60 seconds, and other documents you print typically take as long, the print speed is normal. Troubleshoot this issue only if your product is designed to print faster than about 60 seconds a page or if printing is slower than usual.
***** IF THE PRINT SPEED IS MORE THAN 60 SEC.
Check the power supply. to check the power supply you need to follow these steps.
1. Turn the product so that you can access the rear side.
2. Unplug the power cord from the back of the product.
3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
4. Plug the power cord directly into a wall outlet.
5. Print and time a self-test again.
If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet. If the test page takes significantly longer than 30 seconds to print, continue to the next solution.
CHECK THE CARTRIDGE COMPATIBILTY.
Incompatible cartridges can cause the slow printing problem.
Which cartridges you use depends on your country or region. To check the cartridge compatibility you can go to this site (for hp printers) http://www.hp.com/buy/suresupply and check The number on the cartridge label must match the numbers listed on HP SureSupply.
PERFORM A RESET.
1. Press the Power button and turn off the printer.
2. unplug the power cord. Disconnect the data cable(USB,Ethernet depending upon the the product set up). wait for 30 secs. reconnect all the cable and than try to print a test page.
if these steps resolves the issue than you dont need to continue troubleshooting or if the issue persist than Replace the Power supply for your product.
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
I have a HP Professional Deskjet 1220C. It starts off printing full colour images ok but about a quarter of the way through it starts printing in red. Please help me.
Try the following below if it continues to print in red half way through then either your ink carts have expired or something is wrong with them if you are using coral draw to print images there is know problems with that I have listed the solution to that as well. please tell the results of the test page as well please. and also I have included a few other tests please run through these. The sample page can be used as a quick check of the image quality from the black and color print cartridges. Unlike most printing, this page prints from the bottom of the page to the top for user viewing during printing.
  1. Turn the printer off and then turn it on again by pressing the POWER button.
  2. Press and hold down the RESUME button and release it when the Power light starts to blink.
The sample page can also be printed from the Toolbox (provided the Toolbox is installed) to verify that the printer is connected to the computer properly and that the printer and printer software are working properly.
  1. Double-click the Toolbox icon on the Desktop or run it from the HP Deskjet 1220C Printer program group.
  2. Select the Printer Services tab and click Print a Test Page
Printing the diagnostic page The information displayed on the diagnostic page includes the printer model, serial number, service ID (born-on date), firmware revision, total page count and last error code (see Figure 2). If an error code (hex) number is displayed, it represents the last error that occurred regardless of whether the problem that caused the error has been fixed and the printer is presently operational. To print a diagnostic page see the following:
  1. Turn the power on.
  2. Press and hold down the POWER button.
  3. While holding down the POWER button, press the RESUME button four times.
  4. Release the POWER button.
Running the pen recovery diagnostic test If printouts have incomplete text or graphics that are not corrected by cleaning the print cartridges, use the pen recovery diagnostic test. The pen recovery diagnostic test is a three-level cleaning procedure that attempts to clear blocked print cartridge nozzles. The tests can be run either from the Toolbox under Printer Services or by pressing the button sequences below. The Level 1 print cartridge cleaning is a light cleaning mode. Use this level first to clear blocked nozzles.
  3. While holding down the POWER button, press the CANCEL button twice.
After running the Level 1 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 2 pen recovery. The Level 2 cleaning is an intermediate cleaning mode to be used if the Level 1 mode does not recover the nozzles.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button once.
After running the Level 2 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 3 pen recovery. The Level 3 cleaning is the most intensive cleaning mode that takes about two minutes to complete. Use this level as a last resort in recovering clogged nozzles. This routine uses a considerable amount of ink.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button twice.
After running the Level 3 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If irregular gaps still appear in the printout, replace the cartridge. NOTE: Do not use the pen recovery tests unnecessarily or the life of the print cartridge will be shortened. Printing the nozzle pattern test This test prints a pattern to determine which nozzles, if any, are clogged or not firing and can be used to verify a successful cleaning routine (see Figure 3). Look for irregular spaces or gaps in the test pattern; these indicate faulty nozzles.
  3. While holding down the POWER button, press the CANCEL button eight times and the RESUME button four times.
Printing the calibration page This test provides calibration of the print cartridges. Calibration includes print cartridge alignment and optimizing the turn-on energy for the installed color print cartridge.
  3. While holding down the POWER button, press the RESUME button three times.
Eight green checks, one on each line of the printout, signify that the calibration was successful. ----------------------------------------------------- Printing the infinite H test This test prints continuous pages of the letter H and is useful for troubleshooting paper feed problems or other intermittent problems that are difficult to replicate.
  1. Turn the printer on.
  3. While holding down the POWER button, press the RESUME button eight times.
  5. Press and release the POWER button to terminate the test.
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
2answers
Diagonal lines on print
Follow these steps.
Print Quality Problems on 3010cn.
Reset the NVRAM On the 3010cn
To reset the NVRAM, perform the following steps:
  1. Press the Menu button.
  2. Press the down%20arrow%203100cn.jpg (down arrow) button on the printer until Configure appears, and then press the right%20arrow%203100cn.jpg (right arrow) button on the printer or return%20arrow%203100cn.jpg (Set) button.
  3. Press down%20arrow%203100cn.jpg on the printer until Maintenance appears, and then press right%20arrow%203100cn.jpg on the printer or return%20arrow%203100cn.jpg.
  4. Press the down%20arrow%203100cn.jpg until Init NVRAM appears, and then press right%20arrow%203100cn.jpg or return%20arrow%203100cn.jpg.
  5. Press return%20arrow%203100cn.jpgInitializing and Restart Printer will appear.
  6. Power off the printer and power back on.
To print the Gradation [ESS] test print, perform the following steps:
  1. Power off the printer.
  2. Hold down the up and down arrow buttons on the printer and power the printer on. This will bring up a Customer Mode menu.
  3. Press the down arrow button until Test Print appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow button until Gradation [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. On the LCD, Processing appears and the test page is printed.
To print all four 20% toner test prints, perform the following step:
  4. Press the down arrow until Cyan20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  5. Press the return%20arrow%203100cn.jpg button. The test print will print.
  6. Press the Cancel button.
  7. Press the down arrow until Magenta20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  8. Press the return%20arrow%203100cn.jpg button. The test print will print.
  9. Press the Cancel button.
  10. Press the down arrow until Yellow20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  11. Press the return%20arrow%203100cn.jpg button. The test print will print.
  12. Press the Cancel button.
  13. Press the down arrow until Black20% [ESS] appears and press the return%20arrow%203100cn.jpg button.
  14. Press the return%20arrow%203100cn.jpg button. The test print will print.
  15. Press the Cancel button.
  16. Power off the printer and power back on.
Reseat the drum cartridge, perform the following steps:
  2. Unplug the power cable.
  3. Pull to open the front cover and then lift to open the top cover. (Figure 1)
    Figure 1 - Open Front and Top Covers
  4. Raise the lever on the top right side of the drum cartridge. (Figure 2)
    Figure 2 - Raise Lever to Release Drum Cartridge
  5. Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
    Figure 3 - Remove Drum Cartridge
  6. Insert the drum cartridge.
  7. Close the top and front covers.
  8. Plug in the power cable.
  9. Power on the printer.
k24674
Grand Canyon Tech
Grand Canyon Tech
