SOURCE: I've just replaced the lamp
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything ok then may be the circuit have some problem, go to the nearest sharp authorize service center or visit website.
